Post by scooterpimp on Jun 15, 2014 6:55:58 GMT -5
Keep us posted.
Post by Jwhood on Jun 15, 2014 13:05:12 GMT -5
So today I got a 2007 tgb r50x from my brother it needs some farings piece and a few other things but other then that it's pretty solid,any who I found a tgb mechanic down I southern md that is gonna diagnose my key west next Saturday and see why she ain't running right he has alot of experience with tgb so I figured what the hell and let him fix it,everything is stock except the 17.5 mm carb and the Mrp pipe I'm running a 75 m.j and I'm at sea level and also I bought some iso heet too put in gas too get any water out that was in there
2007 tgb key west,with motoforce 50cc replacement cylinder head &piston,Mrp racing pipe and 19mm carb and a small tachometer!!!!
Post by moofus02 on Jun 15, 2014 13:37:24 GMT -5
I've herd those mrp pipes can run rich till the pipe hits and then lean out. A 75 mj sounds on the lean side with a 19mm carb at sea level with a 50cc Cylinder kit
Post by Jwhood on Jun 15, 2014 18:02:56 GMT -5
Moofus what do u suggest,I finally got it to idle today once it warmed up and I got all air leaks sealed and open an outlet on stock air box by taking a plastic restrictions ring out of it it idle great but I have idle screw all the way in and air fule mixture screw about 3 turns outs she idled just around 805 and 820 Rpms and the carb is actually a 17.5 mm not a 19 mm measured the orfice inside circumference!!!
Post by moofus02 on Jun 15, 2014 18:31:08 GMT -5
It might be fine just make sure it isn't lean once it hits.
Post by Jwhood on Jun 15, 2014 19:39:37 GMT -5
Thanks again for the suggesstions
Post by Jwhood on Jun 17, 2014 16:35:31 GMT -5
Didn't want to start a new thread do u think fixing up the tgb r50x that I just got from my brother would be worth fixing it needs a new back tire a carb and it's not getting no spark?I know sometimes when a scooter doesn't get spark it could be alot of things
Post by 2TDave on Jun 17, 2014 17:35:43 GMT -5
Probably not. Want to sell it?
Post by 90GTVert on Jun 17, 2014 18:32:33 GMT -5
If the parts are interchangeable you may be able to swap from your scoot to that one to see if you can find the cause of no-spark easier and without putting out any money.
Post by 2TDave on Jun 17, 2014 19:57:53 GMT -5
I was kidding btw. If it were me I'd fix it and then sell it unless you want two scoots.
Post by Jwhood on Jun 17, 2014 20:16:57 GMT -5
I'm up in the air about getting rid of it I like the look of the r50x better and the bigger wheels and the r50 has better gearing and another question is the morini engine on these able to be converted to liquid cooled??Here is link where I found stuff that possibly might work it doesn't include the cylinder head they sell that separate I'm wondering if I can find these parts in the u.s I know I will need the radiator and hoses and pump among other things this is what I was thinking of doing on the tgb r50x and sell it for a nice profit!!! www.scooterpartsxl.com/cilinder-motoforce-suzuki-en-aprilia-sr-met-morini-50cc-lc2007 tgb key west,with motoforce 50cc replacement cylinder head &piston,Mrp racing pipe and 19mm carb and a small tachometer!!!!
Post by Jwhood on Jun 20, 2014 18:03:15 GMT -5
So now I went for a 10 Mile ride and the engine hesitates slightly and the throttle seems too get stuck for 20 seconds or so when I let off throttle and when going down hill it wants to keep going what's causing that it idles fine now I unhooked the electronic choke she will idled soon as I start it up,still running 75 m.j any ideas on the throttle sticking
Sent from my HTC6525LVW using Tapatalk
Post by 2TDave on Jun 20, 2014 18:05:14 GMT -5
Revs sometimes will hang up when it's lean. What's the plug look like?
Post by Jwhood on Jun 20, 2014 19:03:49 GMT -5
I'll have to check thanks for the advice took it too a guy today and he didn't know Jack about 2 strokes,I might need too bump up to 80 m.jand put the AF screw in slightly
Post by Jwhood on Jun 21, 2014 14:57:51 GMT -5
So I plug chopped and sparkplug is slightly wet adjust at screw in a 1\2 turn no change throttle still sticks at 2200 -2300 rpm and after I stop it settles down about 5 seconds later here is video of me riding on it at that point it wasn't doing it... Tgb keywest running issues: youtu.be/M6MgOq8w1MUSent from..................
