Post by 2TDave on Jun 21, 2014 15:38:10 GMT -5
I think with what you were doing there you were loading it up. Mine will do the same thing pulling into the garage if I'm on and off the throttle. Does it hang up if your actually riding and stop say at a light?
Post by Jwhood on Jun 21, 2014 15:52:39 GMT -5
Yeah or say if I'm going down my drive way it's has a slight slope at front of driveway I t will do it there too and at a stop sign or stop light or even going down a hill and if I let off the trottle it will still hang I even try to rev it loose too get it too calm down but it takes 5 -10 seconds,I'm about 2 1\2 turns out on the af screw if I screw it in anymore she wants too stall, I'm running stock air box with the restrictions removed too let more air in these things are so touchy first I thought my seat bottom was hitting throttle cable but that isn't it,my needle has 5 groves on it I'm on the 3rd slot up from the bottom!!!
Sent from..................
Post by 2TDave on Jun 21, 2014 16:44:02 GMT -5
What main jet?
Post by 2TDave on Jun 21, 2014 16:55:17 GMT -5
You should be able to twist the throttle and let go of it and hear the slide hit.
Post by Jwhood on Jun 21, 2014 17:38:30 GMT -5
75 m.j and a 17.5 carb and stock 50cc head with 90's stock air box mod so airboc will fit new carb and I don't ever here slide or feel slide hit when I let throttle go also I looked at exhaust to make sure no oil was leakink out the exhaust after I put new studs in and a little oil is leaking out again damn scooter
Post by Jwhood on Jun 22, 2014 12:19:14 GMT -5
I put 85mj in it is running now af screw is 2 1\2 turns out and needle is at the top slot and I still have the sticking of throttle I'm wondering if slide is sticking and also notice when I got back from 4 mile ride my carb bowl was leaking,here is video of the above mentioned.... Tgb keywest with 17.5 mm carb,85 main jet,stock 50: youtu.be/iN6vmAqAo-gSent from..................
Post by Jwhood on Jun 27, 2014 22:11:37 GMT -5
Scoot is running good now,actually better then ever running the 85 m.j and the needle is on 2 slot down from top of needle thanks for all the advice,also where can I buy final gears was thinking about getting taller ones and I'm running red clutch springs now I ordered the yellow 1500 rpm what torque spring should I use in conjunction with the yellow 1500 rpm springs? Also do those torque springs cups with the ball bearings give you better/smoother shifting and are they available in the u.s???
Post by 2TDave on Jun 28, 2014 5:50:00 GMT -5
Check partsforscooters.com for the spring base. A 1k contra should work for you but you may need to adjust roller weight. Not sure about the gears. What motor is it?
Post by Jwhood on Jun 28, 2014 10:05:53 GMT -5
Its the morini engine I also cut out slots up high on the cvt cover to ventilate the clutch and variator I noticed a little improvement while riding for long periods of time
Post by 90GTVert on Jun 29, 2014 9:18:47 GMT -5
I think MRP carries a good bit of parts for the TGB Morinis. The bal bearing bases do seem to smooth things out a bit, but some don't seal well on the torque driver and sling grease. If you find one make sure it looks like it matches up to your current setup in the sealing area if you can. For example some are tapered at the base when they need to be straight down to interact with stock seals properly.
Post by Jwhood on Jun 29, 2014 11:14:25 GMT -5
Post by 90GTVert on Jun 29, 2014 11:41:09 GMT -5
Doubt it. The Morini pulley I have is has a larger diameter TD than my Minarelli stuff.
Not sure if MRP is in business for sure but their site is still up and some of their dealer sites are still up.
Post by Jwhood on Jul 2, 2014 7:02:01 GMT -5
My variator has 26 splines what performance variator can I use,I know mrp but how about koso or hoca or any other alternatives??
Sent from my HTC6525LVW using Tapatalk
Post by 90GTVert on Jul 2, 2014 12:41:45 GMT -5
Post by Jwhood on Jul 5, 2014 14:42:38 GMT -5
So I ordeded the mrp variator and I can't find anywhere that tells me what size weights it take,like 16x13 or 17x12 also trying too get a 1500 rpm torque spring too go with my 1500 rpm clutch springs,I don't think any weights come with the variator at all I think its just the bushing and face drive if I'm not mistaken
