Post by pete130 on Oct 22, 2019 0:06:29 GMT -5
Well I nearly set fire to my bike so over it some times another blown motor dam dam dam starting to wonder if I know any thing starting to cost to much but strange I only get 30 houres out of both motor till they pop hole in piston was riding very slow had temp gage only 160c have had much hotter so another pull down can do in sleep now lol and I'll take a few pics so u can laugh again wow how hard is it. Only a bloody 2 stroke
Post by aeroxbud on Oct 22, 2019 0:41:56 GMT -5
Post by collinsd84 on Oct 22, 2019 18:49:19 GMT -5
Wow! sorry to hear that.
Post by dexameth on Oct 25, 2019 8:31:44 GMT -5
Sonia got the Scorpion pipe last night. Swapped cylinders and pistons too, as I had a stock piston that I cut the windows open and the same with the lower cylinder ports on a spare stock cylinder. More flow. Installed a single ring only on the piston as well. I pulled the cylinder studs out of the case to be able to do the work without dropping the engine, but when I reassembled they felt loose. Like I can spin them by finger. Upon reinstall everything snugged down just fine though. I did 3 base gaskets and no head gasket in attempt to raise the ports just a hair and still maintain good squish.
Now me being me, I didn't measure anything nor take photos... derp. I was in a rush because I saw rain clouds rolling in, which did get me but only a little bit. I'm a driveway mechanic, gotta get it done somehow! Was able to throw a cover over everything and in 5 minutes it was done, ground barely wet. Hardest part of the job was getting the piston circlip out, the one facing the scooter.
Fired up almost instantly with the choke and the electric start. Idled for a few, warmed up and took off. She feels even more powerful! Lots of more go go for sure, she revs higher and keeps pulling... all with the stock 20/20 carb and filter and bellow. I gotta check the plug still but it feels great.
EDIT: Here's a quick video I made riding to work this morning...
Post by aeroxbud on Oct 26, 2019 9:40:28 GMT -5
Replaced the vacuum pipe from the tank, to the carb, on the slider. Had to remove the tank to do it. Not a hard job though. Wanted to remove the restriction from the variator on the typhoon. It had a couple of security bolts in the cover. Never seen this style before. Like an allen head, but shaped like a house! That didn't stop me. But this did! IMG_20191026_100132 by aeroxpaulWhy are you laughing milly
Post by chehystpewpur on Oct 26, 2019 17:04:39 GMT -5
Replaced the vacuum pipe from the tank, to the carb, on the slider. Had to remove the tank to do it. Not a hard job though. Wanted to remove the restriction from the variator on the typhoon. It had a couple of security bolts in the cover. Never seen this style before. Like an allen head, but shaped like a house! That didn't stop me. But this did! IMG_20191026_100132 by aeroxpaulWhy are you laughing milly well thats a new one kinda. the old honda spree 2 strokes had something similar for a restrictor. they had a fixed pulley on the front with a spacer built into one side. with some time on a grinder you could grind that nub off and make the pulley alot taller. it would just about double the top speed of them but took a while to get up to speed.
Post by aeroxbud on Oct 26, 2019 18:55:31 GMT -5
Replaced the vacuum pipe from the tank, to the carb, on the slider. Had to remove the tank to do it. Not a hard job though. Wanted to remove the restriction from the variator on the typhoon. It had a couple of security bolts in the cover. Never seen this style before. Like an allen head, but shaped like a house! That didn't stop me. But this did! IMG_20191026_100132 by aeroxpaulWhy are you laughing milly well thats a new one kinda. the old honda spree 2 strokes had something similar for a restrictor. they had a fixed pulley on the front with a spacer built into one side. with some time on a grinder you could grind that nub off and make the pulley alot taller. it would just about double the top speed of them but took a while to get up to speed. I know up to last year, it was a removable ring. It's a shame as the Piaggio variator is quite good. Another unexpected purchase coming up! Lol
Post by fuzzyruttin on Oct 26, 2019 21:51:10 GMT -5
Added huge nitro can.. no wait, reserve fuel tank... ah kidding, it's just a yeti. Fits snug and looks... what the hell is it
Post by Deleted on Oct 28, 2019 6:27:35 GMT -5
First test ride with Hondaki LT50 reverse tricycle. Scary experience. Goes straight fine, but turning wasn't easy. Who would have guessed? . Carb needs serious tuning.
Post by aeroxbud on Oct 28, 2019 9:36:53 GMT -5
First test ride with Hondaki LT50 reverse tricycle. Scary experience. Goes straight fine, but turning wasn't easy. Who would have guessed? . Carb needs serious tuning. Needs more power. Then you can steer it with the rear end! 😆
Post by christopher on Oct 28, 2019 10:32:58 GMT -5
Replaced the vacuum pipe from the tank, to the carb, on the slider. Had to remove the tank to do it. Not a hard job though. Wanted to remove the restriction from the variator on the typhoon. It had a couple of security bolts in the cover. Never seen this style before. Like an allen head, but shaped like a house! That didn't stop me. But this did! IMG_20191026_100132 by aeroxpaulWhy are you laughing milly Mount it in a drill press and use a file to turn the restrictor down to size. A machine shop should be able to mount that in a lathe and turn it to size in a few minutes also.
Post by aeroxbud on Oct 28, 2019 15:15:57 GMT -5
Replaced the vacuum pipe from the tank, to the carb, on the slider. Had to remove the tank to do it. Not a hard job though. Wanted to remove the restriction from the variator on the typhoon. It had a couple of security bolts in the cover. Never seen this style before. Like an allen head, but shaped like a house! That didn't stop me. But this did! IMG_20191026_100132 by aeroxpaulWhy are you laughing milly Mount it in a drill press and use a file to turn the restrictor down to size. A machine shop should be able to mount that in a lathe and then it to size in a few minutes also. I have just ordered a new variator. Then if for any reason I need to, I can return it to stock.
Post by oldunclestevo on Oct 28, 2019 18:08:43 GMT -5
I rode the hell out of my chinese beast. To infinity and beyond!
Post by aeroxbud on Oct 29, 2019 6:09:42 GMT -5
Realised my helmet won't fit under the seat. It's not even a large helmet, small size Arai. Was so looking forward to having somewhere to put my lid again.
Post by fuzzyruttin on Nov 2, 2019 20:55:15 GMT -5
