Post by milly on Jan 21, 2020 15:30:39 GMT -5
Today I got the Rat running perfectly at last and also had a light bulb moment why its a hard starter. But knowing me I maybe wrong. I then went for a coffeee and roll on Violet and then decided to put the new feet on. Trouble is one had stripped threads Dammo!
Post by dexameth on Jan 21, 2020 16:18:15 GMT -5
milly try larger gauge wires from battery to solenoid and then solenoid to starter motor LET THE JUICE FLOOOWWWWW
Post by milly on Jan 21, 2020 16:59:02 GMT -5
I think I will try that dexameth.My reasoning was after swapping carbs over on the80 and 70cc barrels both with a 50cc head and extra base gasket the compression was just to high. My reckoning on that was I got my sons one running his being 80cc kit but with a 80cc head as well with the same carbs I used on mine. Lesson learned I thought, but I do remember it started much better with a car battery and jump leads.😊 Try it I shall the force is with me
Post by 2stroked on Jan 21, 2020 20:53:59 GMT -5
Snow on the ground so no work today. Swapped rings and piston, new cage bearing, and clips, fought with reeds, and eventually got a good seal. Got a few.pips, some fire and a bit of smoke (no pipe, haven't installed it yet...) No start, but it wants to. This Beamer is pissing me off....
I had to stop for the night, or I'd have set it on fire....
Post by aeroxbud on Jan 22, 2020 4:27:21 GMT -5
Snow on the ground so no work today. Swapped rings and piston, new cage bearing, and clips, fought with reeds, and eventually got a good seal. Got a few.pips, some fire and a bit of smoke (no pipe, haven't installed it yet...) No start, but it wants to. This Beamer is pissing me off.... I had to stop for the night, or I'd have set it on fire.... Yes, sometimes you have to know when to walk away.
Post by 2stroked on Jan 22, 2020 7:57:11 GMT -5
Snows gone. Mixed emotions. Guess the only thing I'll do to the bike today is mentally cuss at it... And audibly.
Post by Tanuki on Jan 26, 2020 17:59:13 GMT -5
Painted brake pedal
Post by aeroxbud on Jan 26, 2020 20:56:43 GMT -5
Over the last couple of days. Changed the throttle cable to a one piece design. Junked the cheap 17.5mm carb. It never seemed to work as good as it should. Back to an old 12mm carb I had laying around. Definitely a loss of top end power. But it's my ride to work scoot. Noticed today that old carb bowl was leaking. Changed out the gasket for a new one. On reinstalling the carb it overflowed. Once I took it off again. I noticed the needle valve was sticking shut. Replaced with another from a different carb. Fitted the new rear brake cable.
Post by dexameth on Jan 27, 2020 11:21:57 GMT -5
(Yesterday) rode my scooter like 60 miles to help a friend with his Elite E. Needed to get it running before Valentine's Day so I figured I could help him out. The dang replacement carburetors have the autoenricher on the right side which contacts the rear shock. The stock carb had the enricher needle stuck in, so I rebuilt that stock carb with all the internals from the new carb. First install - the needle stuck and leaked everywhere. Whoops! Pulled a tiny little metal flake out of the needle seat, refitted and all was well.
Had to hold WOT while kicking over and over to get it to fire, but it did! Said it sat for years and was a freebie. Opened the CVT to find a single-speed design (no variator) so we worried it would be a turtle.
This this rips! Takes off kinda like a 2-speed moped... gets moving then rpms drop and it feels like a mini bike because of the gearing. I sill go it up to about 25mph and quick at that too! Makes me sad I got rid of mine a few years ago...
He's happy, it was fun, and now his girl can cruise around. Win!
leaferreefer
fuck donald trump
Post by leaferreefer on Jan 28, 2020 14:46:44 GMT -5
i finished the borekit on my peacesports engine. now it can go 42mph comfortably, and i can keep up with traffic
Post by 2stroked on Jan 28, 2020 18:12:39 GMT -5
i finished the borekit on my peacesports engine. now it can go 42mph comfortably, and i can keep up with traffic Watch out man, pretty soon foul have an empty set of cases, a stroker crank, four valve head and A9 can in the mailbox.... Its a disease, but its one we all welcome and cherish. Congrats, man.
Post by ryan_ott on Jan 28, 2020 21:05:32 GMT -5
Pulled my forks apart to clean and replace oil. Added a few washers of preload and when with 15wt this time. Note to self stay out of the salt water at the beach. upload hoster ru photo
Post by aeroxbud on Jan 29, 2020 3:50:51 GMT -5
i finished the borekit on my peacesports engine. now it can go 42mph comfortably, and i can keep up with traffic Its a disease, but its one we all welcome and cherish. Yeah, tell my wife that!
Post by 2stroked on Jan 29, 2020 8:42:44 GMT -5
Its a disease, but its one we all welcome and cherish. Yeah, tell my wife that! I'll tell yours, you tell mine. Strangers on a Train style....
tas50
Post by tas50 on Jan 29, 2020 10:30:50 GMT -5
where do you get specs on what the oil levels should be in these little forks? Pulled my forks apart to clean and replace oil. Added a few washers of preload and when with 15wt this time. Note to self stay out of the salt water at the beach. upload hoster ru photo
