Post by aeroxbud on Mar 17, 2024 4:07:12 GMT -5
Repairs and service I used to do for $10-20 now costs $1000... We have laughed at pictures of people needing a whole wheelbarrow full of cash to buy a loaf of bread in some countries. We have been amazed to see 10,000 peso/yen/whatever etc paper bills or notes. Nobody laughs anymore. It feels difficult and dangerous to carry enough cash in a wallet to pay for a decent meal and night out now. I have lived too long, I can no longer afford it, -time to die. Years ago I worked for a company that sent a lot of products to Italy. There were so many zeros on the money transactions. You had to leave one of the Aerox off the end on invoices. We're so glad when Italy joined the European currency.
Post by milly on Mar 19, 2024 11:02:31 GMT -5
It is went for a spin to workon the bike today, school kids love it and did bit of work on scooter this afternoon winner3ty and now we have spark but wrong size throttle cable.
Post by aeroxbud on Mar 20, 2024 7:01:15 GMT -5
When my puller broke, I had to get creative!
Post by milly on Mar 20, 2024 10:35:02 GMT -5
Today I got creative to aeroxbud I played about with my favourite things, old crusty bike electrics.Still got a spark and brake lights now and again worked but nowt else. Checked new ignition switch and one wire away from terminal at switch and two others cracked insulation. By then back aching and fekk it time. Off with the indicators get a make shift switch as unobtainium same as throttle cable. I will put it on premix as friend has single cable that will fit plug all the lights in if they work fine if not cover lens with tape whatever and go for a daylight MOT on it. Can't be faffing to much with it. Still sorted the front brake out and new cable.
Post by Wrenchturner on Mar 20, 2024 10:44:59 GMT -5
I did a valve adjustment for my Solana....only one problem, I snapped the spark plug when reassembling the thing, trying to use the recommended torque wrench specs instead of going for the ol' reliable gutentight. 8 ft-pounds is way too much apparently Luckily, it was a cleaner snap than expected and I fished the debris out. It's too cold to ride much this week anyhow, but I learned my lesson and immediately bought three replacements. Next week seems like it'll be better weather-wise.
Post by FrankenMech on Mar 20, 2024 12:08:16 GMT -5
Chinkinees translations of manuals all must be treated with pounds of salt. If something sounds dubious it probably is. There is no substitute for years of experience, gut feel, knowledge, and observation. Think twice, apply wrench once.
Check the threads in the head.
Post by milly on Mar 24, 2024 10:20:54 GMT -5
Post by milly on Mar 26, 2024 7:52:35 GMT -5
Dad bike won't start. Get there to look while Callum away on training course for the week. Check plug ok check tank empty! Get some fekkin petrol in it son! Check petrol can but full of whatever but not petrol
Post by FrankenMech on Mar 27, 2024 23:05:26 GMT -5
He will probably have expected you to have not only filled the motorcycle with gas, -but to have bought him a new gas can, cleaned the inevitable plastic swarf out, and filled it up also... -Children are like that.
Of course you could have used your trip time wisely and scrubbed the chrome on the entire motorcycle with aluminuminium foil and vinegar to remove the rust and then washed and waxed the mother -F***** also...
-That is what 'friends' remind you about.
Post by milly on Mar 28, 2024 4:48:25 GMT -5
-That is what 'friends' remind you about. Lol I did use it wisely work paid for it 😁
thatmint240
Popping up the 2 stroke
Post by thatmint240 on Mar 29, 2024 17:59:34 GMT -5
Made my own exhaust gasket out of thick cardboard covered in a THICK THICK layer of high temp gasket maker. Let it sit for 20 mins then installed it and no more exhaust leak.
Post by FrankenMech on Mar 30, 2024 0:10:38 GMT -5
Made my own exhaust gasket out of thick cardboard covered in a THICK THICK layer of high temp gasket maker. Let it sit for 20 mins then installed it and no more exhaust leak. It will burn through with time. Once a leak occurs it will burn rapidly. You need to buy some exhaust gasket material from an auto parts store and use it instead of the cardboard. If the exhaust flange does not match the exhaust port you will need to correct any misalignment issues. Gasket sealing surfaces must be closely parallel with each other.
Post by aeroxbud on Mar 30, 2024 14:08:11 GMT -5
New full circle crank installed.
Post by milly on Mar 31, 2024 5:44:03 GMT -5
New full circle crank installed. What scooter is that. I presume it's a spawn of Satan 2 stroke 🫣
