50$ buy
Jul 3, 2014 19:09:23 GMT -5
Post by crs7wv on Jul 3, 2014 19:09:23 GMT -5
so i was looking around on craigslist seen a scoot for 300 $ 100cc 2 stroke... before i even got there i had guy talked down to 150 i got there it wouldnt go over 10mph so i got for 50 figure itll be my first build ... got up early next morning and tore into it had it r7nning about 35mph... while workin on it seemed alot funnier then my dio ..its chain drive jl1pe40qmb i see all kinds of parts for it but everythiny says jog..this is a hortizonal motor please help me understand this
50$ buy
Jul 3, 2014 19:10:34 GMT -5
Post by crs7wv on Jul 3, 2014 19:10:34 GMT -5
Ment to tell y'all geely but idk if its orginal motor
Post by 2TDave on Jul 3, 2014 19:17:57 GMT -5
You can do engine mods but your probably going as fast as you will with the chain drive. You got it cheap. I'd sell it and put the money towards a 2stroke minarelli with a cvt.
Post by 2TDave on Jul 3, 2014 19:19:12 GMT -5
The engine code is for 49cc.
50$ buy
Jul 3, 2014 19:25:53 GMT -5
Post by crs7wv on Jul 3, 2014 19:25:53 GMT -5
Is a swap possible I like this body .. kinda tired of buying ready to build
Post by 2TDave on Jul 3, 2014 19:40:50 GMT -5
Yes. Post a pic of it. My guess is it's a short case and you could pick up one. There's a new 90cc on eBay for I think $200 now or wait and find one for less or a donor scoot.
50$ buy
Jul 3, 2014 20:20:38 GMT -5
Post by crs7wv on Jul 3, 2014 20:20:38 GMT -5
Would that be stayin 2t or goin four stroke
50$ buy
Jul 3, 2014 20:25:06 GMT -5
Post by crs7wv on Jul 3, 2014 20:25:06 GMT -5
When I get home I'll walk out to my shop and take u some pics .. thanks for your help bro
Post by 2TDave on Jul 3, 2014 20:58:24 GMT -5
Staying 2stroke. I wouldn't send you to the dark side. Lol. No problem!
Post by Sitticuss on Jul 4, 2014 2:39:50 GMT -5
Staying 2stroke. I wouldn't send you to the dark side. Lol. No problem! I thought this was the darkside.....darn
Post by 2TDave on Jul 4, 2014 5:45:14 GMT -5
I guess your right. All that smoke does tend to block light!
Post by Sitticuss on Jul 4, 2014 6:19:19 GMT -5
Had the same problem on one of my scooters. cleaned the oil fitting would hold for a few days then it would leak again. Finally just swapped it out with one from an older miki carb that had a better design. Problem solved.
50$ buy
Jul 12, 2014 7:39:28 GMT -5
Post by crs7wv on Jul 12, 2014 7:39:28 GMT -5
I figured out its short ... I need to get the motor off so bad no power and leaks oil every where ... so it'll I can get the money up for the 2t motor I found a gy6:( for 50$ suppose to pick it up tomrrow duct tape fenders and all .. but she says it runs her sonn left it last year when he went south and sh wants the room back in her shed
50$ buy
Jul 12, 2014 11:19:33 GMT -5
Post by 90GTVert on Jul 12, 2014 11:19:33 GMT -5
Is this a vertical engine chain drive? I'd flip it. Not like the Incredible Hulk, but I mean get it looking and running as well as you can for next to nothing and resell. Not a good choice for modding. If you were to add a tuned pipe or do port work it would fall on it's face off the line because it doesn't have a CVT that can be tuned to make the trans work with the engine. You're stuck with a single speed. The vertical ones that I think are more commonly 1E41... have big bore kits so you can up the power, but prob still not great because it's only 60cc and you don't tend to get big power out of these little engines without raising the powerband with porting and a pipe. I'd actually take the GY6 50 (139QMB) over the chain drive 2T. Also not sure how the mounts are on those so a swap may not be easy.
50$ buy
Jul 12, 2014 12:28:46 GMT -5
Post by crs7wv on Jul 12, 2014 12:28:46 GMT -5
Lol yes it most horrible thing ever .. its 100cc no acceleration no up hill ..for 50$ I took it.. I'm gettin the beat up gy6 tomorow the fenders are ducktaped the keys broke in the ignetion it was ran last year for another 50$ looks like I'll have a lil project
