Post by sking3111 on Jul 5, 2014 11:35:52 GMT -5
Hello, I have a 2004 Yamaha zuma stock engine with techna exhaust. 6gram rollars ,red clutch springs and stock main spring. My top end is 30 any ideas on how to get it faster or is this as goog as it gets with stock engine?
Post by 2TDave on Jul 5, 2014 11:41:46 GMT -5
You need to change the contra/torque spring. 1k or 1.5k at most. Those red clutch springs may be a little stiff. The gearing on the Zuma is a hurdle. So once you get the cvt in tune you'll want to do them next. A tach will help you tune the cvt.
Post by moofus02 on Jul 5, 2014 11:54:13 GMT -5
Post by moofus02 on Jul 5, 2014 11:56:21 GMT -5
I think I have yellow clutch Springs in mine with the stock contra and 6 gram rollers. No belt slip good take off and the clutch grabs just before the belt starts to shift
Post by sking3111 on Jul 5, 2014 17:10:32 GMT -5
Thanks for all suggs, I put yellow contra spring on and lost 2 mph top end.
Post by 2TDave on Jul 5, 2014 17:49:34 GMT -5
You could try a 1k but the stock is fine. Moofus knows his Zumas.
Post by usmcdoc on Jul 5, 2014 22:01:06 GMT -5
Hello, I have a 2004 Yamaha zuma stock engine with techna exhaust. 6gram rollars ,red clutch springs and stock main spring. My top end is 30 any ideas on how to get it faster or is this as goog as it gets with stock engine? As Moofus02 said above... Plus if you are using a Tecnigas or any tuned performance pipe...you most likely will need to upjet..since the engine breaths better now.. More exhaust out = needs more air and fuel in... Make sense?..
rexxk
Post by rexxk on Jul 5, 2014 22:37:01 GMT -5
tune the rollers. dr pulleys push a little higher. swap out the stock variator for an aftermarket one.
Post by moofus02 on Jul 6, 2014 9:31:24 GMT -5
tune the rollers. dr pulleys push a little higher. swap out the stock variator for an aftermarket one. All that might help a little but this bike is handicapped with super deep gears. Best money spent would be to re gear. All other mods won't return as expected until the regear Sent from my SPH-L720 using proboards
Post by bclivewire on Jul 6, 2014 9:44:46 GMT -5
2003 zume motor in my 2005 zuma running 70cc bbk stock crank
19mm carb and doppler pipe
6g rolers ( 6.5g are stock ) yellow com. spring with upgraded 3 show clutck
I alsow run a tack so I knoe what RPS it is turnimg
on your set up try stock rolers .. yellow com. spring ( maby stock clutch springs )
I run stock gears because my 400lbs needs it to get moving --- it will spin the tire with my 200lbs fends
rexxk
Post by rexxk on Jul 6, 2014 14:27:57 GMT -5
i guess. tuning the variator twice with roller weights sucks.
Post by 2TDave on Jul 6, 2014 15:39:49 GMT -5
I don't understand that Rexxd. Rollers are like jets. They're simple to do and you work your way up or down until the performance peaks, declines and then go back a step. Change a torque spring and do it all again. I know I'm one of the demented ones that enjoys wrenching as much as riding but I can't imagine it sucking or I would leave it alone.
rexxk
Post by rexxk on Jul 6, 2014 17:16:26 GMT -5
then why tell him not to do it? moofus said. and i said install a variator. so, your saying? that a variator doesnt add any performance? all i said, since he said dont do a variator, sliders, was because, the gears are so limiited. limited i guess, performance gain is what he siad. i said i guess. tuning rollers twice sucks. it does. so, your saying a variator doesnt add any performance gain? do it once, then dont worry about it, or dont do it, do it later if you would but it wouldnt perform any better? because your not giving this guy any perofrmance tips. i gave him the only ones i knew.
back to me. try a variator and sliders. sliders give more performance than rollers. and a variator, adds performance too. yea if you changed the performance killing gears, youd have to change the roller weights later on too, i think. and retune. get more rollers. if performance is that bad off, wait, until you change the gears. but i cant see a variator being of no use.
most people who want performance from goign 35mph, usually want to see, oh 40-45. a variator usually will add some 5mph. and then lightened roller weights will add you 2-3mph if not more. and sliders, can add a few mph also. thats what ive seen.
are you saying that variators do nothing? no perforamcnce benefit at all? their a waste? man i been wasting my money, but the perforamnce ive seen sure showS!
Post by 2TDave on Jul 6, 2014 18:13:52 GMT -5
Nobody said a variator is useless. It's one if the first mods I did. On a scoot with good gears! When gears max out that's it. If I add your variator and roller numbers up that's 10+ mph. Come on man. I didn't realize your tuning rollers twice comment was sarcastic. I'm not sure if that's better or worse.
Post by Sitticuss on Jul 6, 2014 18:27:48 GMT -5
You locked in tight with those gears man. You gotta have the tranny built up tight first or your done.
