Post by iwiketuddlz on Jul 6, 2014 11:31:52 GMT -5
Hey guys my performance variator keeps failing, I dont get why,it keeps eating up the 3 sliders really quickly. Plz help what is causing this??
Post by oldgeek on Jul 6, 2014 14:28:15 GMT -5
If it is opening too far, the slides will break quickly. Set the assembly on a flat surface and see if it is opening up past the metal part of the ramp plate.
rexxk
Post by rexxk on Jul 6, 2014 14:28:51 GMT -5
is your belt got slack? if its broke nad hit metal to metal once, it starts digging a ditch in the variator and the slides will follow that and break. what made them break in the first place?
Post by scooterpimp on Jul 6, 2014 14:53:50 GMT -5
Is engine over reving before clutch engages? Like worn clutch? , too heavy springs?
rexxk
Post by rexxk on Jul 6, 2014 17:42:16 GMT -5
worn? why is it you guys go to every forum saying the same old crap that youve made up before. ive seen racing scooter and i guess we all should switch over to chains since these cvts cant handle all this awesome torque where throwing at them
id say if your clutch pads are worn your guides in teh variator are also around that time needing changed
Post by 2TDave on Jul 6, 2014 18:26:25 GMT -5
I'm with OG on this one. It has been brought up before.
Post by iwiketuddlz on Jul 6, 2014 18:53:33 GMT -5
Everything is new the entire transfer kit, yes the sliders disappeared and the back plate dug into the variator, Yea that's what I figured I have way to much tork and power, but I can put the stock variator in and it does fine I just don't like the way it's geared,I like the performance much better I went and bought another performance calorie but this time I have been checking it and sure enough it's eating up thee sliders on this one too sigh I wish they made a variator that can hold up
rexxk
Post by rexxk on Jul 6, 2014 19:23:27 GMT -5
maybe you got cheap guides. once a variator takes metal to metal contact, they dig a ditch and the slides cant go up and down straight. its not flat anymore. theyll crack and break. and might take out your belt. teh variator doesnt have much in gearing. the gear would be the front pulley, back pulley. a pulley isnt a half a ramp. its v-belt. theres no angles. they have to match the belt. most of the angles are in the variator. and the ramp plate. i dont believe this story no longer. unless your using the wrong bikes variator. if your using a variator for a bike that has a 30 angle belt and your belt is 28, well that right there can cause problem. or even if you bought one, if these people been lying about what kind of variator you can use youll then notice theyll be for sale marked as that. you have toknow how they measure. measure them. know what bikes theyre from. then theyll never tell the truth theyll just lie.
Post by scooterpimp on Jul 6, 2014 19:24:41 GMT -5
worn? why is it you guys go to every forum saying the same old crap that youve made up before. ive seen racing scooter and i guess we all should switch over to chains since these cvts cant handle all this awesome torque where throwing at them id say if your clutch pads are worn your guides in teh variator are also around that time needing changed Oooookkkkkk ......Just tring to help this dude with some Ideas,?
Post by iwiketuddlz on Jul 6, 2014 19:49:11 GMT -5
Thanks for the info I took about a 16th off the length of my boss, this may help although it wasn't too long but whatever helps,anymore ideas? Thanks yuns
Post by iwiketuddlz on Jul 6, 2014 19:51:05 GMT -5
Well hadn't thought of that,how do Tell my angles? That could be it huh?
Post by iwiketuddlz on Jul 6, 2014 19:53:43 GMT -5
Thanks for teh ideas rexx! I shall investigate
Post by 2TDave on Jul 6, 2014 19:53:48 GMT -5
It's not you Pimp.
rexxk
Post by rexxk on Jul 6, 2014 22:00:17 GMT -5
rexxk
Post by rexxk on Jul 6, 2014 22:09:31 GMT -5
worn? why is it you guys go to every forum saying the same old crap that youve made up before. ive seen racing scooter and i guess we all should switch over to chains since these cvts cant handle all this awesome torque where throwing at them id say if your clutch pads are worn your guides in teh variator are also around that time needing changed Oooookkkkkk ......Just tring to help this dude with some Ideas,? everytime my guides break, it takes out my variator. I dont hear this problem very much. if because of that a worn spring or a pad, then thered be lots of variators breaking. noone talks about that? now, do they?
