Post by fraserd on Jul 13, 2014 3:39:55 GMT -5
hi i have been having high idle and erratic. i have cleaned the carby replaced cracked manifold sealed with sealant still got a high and erratic when i rev it it settle for little than go up i sprayed carburetor cleaner around the area the revs than drop but goes back up always thought if it had a air leak idle would be low? not sure whats going on.
Post by shakerdriver on Jul 13, 2014 10:00:39 GMT -5
Its most definitely an air leak. Make sure to check your intake and base cylinder gaskets.
Post by fraserd on Jul 14, 2014 6:41:37 GMT -5
thanks yes air leak at the base gasket.
