Post by syko on Jul 16, 2014 18:08:50 GMT -5
so I have 2 big gapping holes in my motor below my intake in the crank case due to me driving 5 miles with a blown clutch to not have to push it 5 miles, I want to rebuild what are my options beside the stroker motor and stock I want to know all my options I have a 2011 tao tao 50 budget probably is about 400 preferably closer to 300 though
Post by stevec on Jul 16, 2014 18:55:10 GMT -5
i had a hole in the block on my taotao GT5 and i used JB quick weld and it never leaked and the stuff is very strong. you could use some thin mesh to spread the JB onto so it covers the hole. it is cheap and it works.
Post by syko on Jul 17, 2014 4:59:23 GMT -5
here is said hole
Post by stevec on Jul 17, 2014 9:45:47 GMT -5
you can get a new part to replace the one with holes pretty cheap, not sure exactly what it is called but it houses the oil pump and has hole for crankshaft bearing. scootusa.com has it for $50
Post by syko on Jul 17, 2014 11:36:32 GMT -5
you can get a new part to replace the one with holes pretty cheap, not sure exactly what it is called but it houses the oil pump and has hole for crankshaft bearing. scootusa.com has it for $50 thank you very much wasnt sure which crank case it was steve and when I fix it if you want to go riding pm me your number I have 2 other friends that go riding weekly we need more peopld
Post by stevec on Jul 17, 2014 12:19:40 GMT -5
if you need a hand installing it let me know, i have rebuilt a lot of GY6 50's i have a 150cc that i am doing a little bit of modification with.
Post by syko on Jul 17, 2014 14:18:07 GMT -5
if you need a hand installing it let me know, i have rebuilt a lot of GY6 50's i have a 150cc that i am doing a little bit of modification with. I appreciate it thanks I will definitely let you know ill be ordering parts soon hopefully if I can snag a few more hours at work this week
