Post by draven0914 on Jul 19, 2014 2:11:03 GMT -5
Hello again all thank you to everyone that has helped me up to this point.....so I've been out riding my scoot but I went out to start it today and it would not start......the gas is full and the kill switch is off (or at least it appears to be) it has only been sitting maybe a week..........PLEASE HELP!!!!!!!!
thank you
Justin
Post by stevec on Jul 19, 2014 5:32:47 GMT -5
did you try kill switch? does it turn over? did you try to kick start?
Post by draven0914 on Jul 19, 2014 13:34:25 GMT -5
The kill switch I'd in the on position but when I try to stay it it acts like the kill switch is in the of position and just wins instead of staying but it ran beautifully the last time I rode it. ......I'm not sure if I turned it if with the kill switch or not to prevent my kids from trying to ride it
Post by draven0914 on Jul 19, 2014 16:11:50 GMT -5
The kill switch is in the on position but when I try to start it it acts like the kill switch is in the off position and just whines instead of starting but it ran beautifully the last time I rode it. ......I'm not sure if I turned it off with the kill switch or not to prevent my kids from trying ride it
nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on Jul 19, 2014 16:17:29 GMT -5
Need to pull the plug and see if there any spark there, if it has spark then move to the fuel system have you swapped the fuel petcock out with a manual shut off if it might be off.
Post by stevec on Jul 22, 2014 4:40:12 GMT -5
try to kick start and see if it starts. check for spark and fuel, you should see fuel in the fuel filter. the kill switch will prevent spark, look at the pic above the switch and make sure it is not towards the one with the X. it is a good idea for the manual petcock, i will be installing one on mine, much better than the vacuum petcocks.
Post by draven0914 on Jul 22, 2014 16:34:33 GMT -5
Thank you everyone the issue was a loser connection with the coil. ... got it ask tightened up and everything rubbing well again. .....I want the manual shut off petcock..... where might I find one? And thank you everyone again
nightriderrv
Post by nightriderrv on Jul 22, 2014 22:05:51 GMT -5
