Post by chesron on Jul 23, 2014 17:42:49 GMT -5
Hey guys, i have a yamaha axis and just replaced the crankshaft and a few other parts. The problem is now it won't start after reassembling everything. I've tried everything i can think of. Any suggestions?
Post by bclivewire on Jul 23, 2014 18:05:06 GMT -5
make shore the battery is fully charged
I had to remove the air filter to cover the opening if the carb to get mine to start for the first time
Post by niz76 on Jul 23, 2014 18:54:05 GMT -5
Low compression from a leak?
Post by chesron on Jul 23, 2014 21:38:47 GMT -5
I removed the air filter and did that, but it didn't work either.
Post by Upgrayedd on Jul 23, 2014 21:41:37 GMT -5
-carb is primed? -got spark? -no loose/leaking vacuum lines/connections?
Post by chesron on Jul 23, 2014 21:41:47 GMT -5
But it could be low compression, because the crankshaft moves a little stiffly.
Post by chesron on Jul 23, 2014 21:45:50 GMT -5
Yes as far as i know the carb works fine. I think the problem may be that fuel doesn't get into the cilinder, because the spark plug doesn't seem wet. Any suggestions on fixing that?
Post by Upgrayedd on Jul 23, 2014 22:00:07 GMT -5
axis is a 2stroke, yes?
Post by chesron on Jul 24, 2014 8:04:45 GMT -5
Yes it's a 2 stroke.
Post by 90GTVert on Jul 24, 2014 10:24:55 GMT -5
Did you feel a strong vacuum when you held your palm over the carb's inlet? Hand get wet with fuel?
Post by chesron on Jul 24, 2014 10:36:14 GMT -5
No it wasn't that strong and i did feel a little fuel on my hand.
Post by 90GTVert on Jul 24, 2014 11:03:08 GMT -5
It could just be having trouble picking up the fuel. Some of them struggle on the first start and then start and run fine after they get going once. If holding the hand over doesn't work, sometime a quick shot of carb cleaner or starting fluid through the carb (throttle held open so you can spray through) will be enough to get it started.
Post by chesron on Jul 24, 2014 12:14:42 GMT -5
I've just tried it with carb cleaner but it didn't start. I have noticed that there's no fuel coming in the cilinder.
Post by 90GTVert on Jul 24, 2014 12:58:57 GMT -5
If it's strictly a fuel issue it should start with carb cleaner acting as a temp replacement fuel. Verify that you have spark before going any farther. www.youtube.com/watch?v=LogSfY7NhkQ
Post by chesron on Jul 24, 2014 16:12:00 GMT -5
I already check for spark, there is.
