Post by johnrm on Jul 30, 2014 10:44:49 GMT -5
Upgraded the main jet (80 from 74) put it back together and it ran good on the stand. Turned it off and adjusted the play out of the throttle cable. 20 hours later and it wont start with the choke on or off. I can hear the starter but theres no smell of fuel.
Post by 2TDave on Jul 30, 2014 12:31:35 GMT -5
Is it possible you have the cable too tight and it's opening the slide?
Post by johnrm on Jul 30, 2014 13:21:46 GMT -5
I could try switching it back. Would that keep it from starting though?
Post by 2TDave on Jul 30, 2014 13:51:59 GMT -5
If it's to tight and raising the slide it's the same as giving it throttle so yeah it could.
Post by 190mech on Jul 30, 2014 18:27:22 GMT -5
If it's to tight and raising the slide it's the same as giving it throttle so yeah it could. Right on Dave!If the slide is opened slightly the choke circuit is inoperative..
Post by johnrm on Jul 31, 2014 11:29:36 GMT -5
I was able to return the throttle cable to its previous condition but it didn't seem to make any difference b/c it still wouldnt start.
Are there any common mistakes that i could have made rejetting the carb? Is there a checklist of sorts? When i did the work i only removed the bowl to access the main jet. Could i have messed something up when i reassembled it since it worked before..so maybe its not the jet or throttle position thats the reason it wont start?
Thanks again guys. I just want it to work..thats all..
Post by 2TDave on Jul 31, 2014 12:20:07 GMT -5
Try pulling the plug. It may have gotten flooded. If a piece of dirt got in the jet that could cause an issue. If cleaning and drying the plug doesn't do it you may want to clean the carb and jet with carb cleaner and compressed air.
Post by johnrm on Aug 3, 2014 17:06:35 GMT -5
Ok pulled the plug, cleaned it and reinstalled it. Still wont start. Its not getting fuel for some reason. any thoughts
Post by 2TDave on Aug 3, 2014 17:26:30 GMT -5
Have you checked to make sure the vacuum petcock is working? If you suck on the vacuum hose at the end that goes to the carb with the fuel line off you should get fuel coming out the fuel line.
Post by johnrm on Aug 4, 2014 14:10:01 GMT -5
Dave,
There seems to be two hoses that attach to the "vacuum fuel tap". i take it that ones the fuel hose and the others the vacuum hose. Is there a way to tell which is which?
When i removed the carb bowl i used a clip to pinch both hoses closed so they didnt spew fuel everywhere. I also let the motor idle with the clip in place once..
Post by 2TDave on Aug 4, 2014 14:33:47 GMT -5
The vacuum hose should come from the intake side of the carb the fuel from the other side(air filter side) if you suck on one and get fuel in your mouth it was the wrong one. Lol
Post by 2TDave on Aug 4, 2014 14:34:26 GMT -5
Fuel usually comes in up top by the slide cover.
