Post by syko on Aug 9, 2014 14:18:39 GMT -5
Im stumped just did a motor swap ran it up and down the road once now it wont start and ive checked the magneto it gets signal, checked the coil its good, and checked the cdi, its good battery is good as i just charged it every wire was traceable except for these two does anyone know where they go oh its a 2011 taotao
Post by 90GTVert on Aug 12, 2014 13:24:38 GMT -5
If that's the 2 pin plug from the CDI, black/white usually goes to the kill switch. Red/black usually goes to the stator. If there's a ground applied to that black/white wire it will kill the ignition so make sure there's no ground there. Red/black wire should have 50VAC+ on it when cranking.
Post by syko on Aug 26, 2014 5:07:51 GMT -5
the cdi was bad I traced that wire to the kill switch checked continuity it was fine checked the stator and the weird thing was when I put my ac meter on the stator to check voltage while the stator was unplugged it fired right up. so I knew that was good just dont know how that was possible
