2003 zuma Aug 11, 2014 11:08:58 GMT -5 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by refrig on Aug 11, 2014 11:08:58 GMT -5 are there any restrictions that can be removed to increase top speed. stock scooter
2003 zuma Aug 11, 2014 11:24:35 GMT -5 via the ProBoards App Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by moofus02 on Aug 11, 2014 11:24:35 GMT -5 Yes there are. Change the gears before you even consider any power increases. You have 14.64:1 gear ratio and are limited to 30 to 35 mph by rpm. A gear change is the only way to overcome that www.racingplanetusa.com/primary-transmission-gear-racing-1442-tooth-countershaft-p-2052-1.html?cPath=4658_7148_7156&sessID=a60674a327f7f509083fdd6c90af7748#.U-pG0WOHfEeSent from my PG86100 using proboards
