Post by kymcopurvis1 on Aug 19, 2014 14:14:21 GMT -5
Hey there guys new to this forum I have a kymco cobra cross as a project needs some tlc it was sat for 3 and a half years in a friends back garden until I decided to take it off his hands I've had it running but it will only.idle and rev correctly when the rear brake is pulled in and also will the parts from a standard cobra fit? As I've sourced the ones I need on ebay any help extremely appreciated thanks in advance jack
theo547
Post by theo547 on Aug 19, 2014 15:42:07 GMT -5
Check\clean the carb, drain the fuel and replace all of the fuel lines. see what that does for performance.
Personally I don't know anything about these scooters from a parts perspective.
Post by themajekalbum on Aug 19, 2014 21:21:02 GMT -5
I second the clean fuel system, if it ran fine before it was left out chances are that it'll be real close to the same after it's cleaned.
As far as parts you should be able to use vitality parts. I almost always see the cross listed when I get parts for my vitality at least 2t engine wise. What engine you got in the cross? I got a sf10k in my 05 vitality. Can't help on the cross vs standard cobra part fitment though.
Post by usmcdoc on Aug 19, 2014 22:24:29 GMT -5
Hey there guys new to this forum I have a kymco cobra cross as a project needs some tlc it was sat for 3 and a half years in a friends back garden until I decided to take it off his hands I've had it running but it will only.idle and rev correctly when the rear brake is pulled in and also will the parts from a standard cobra fit? As I've sourced the ones I need on ebay any help extremely appreciated thanks in advance jack The problem you have is a bad/corroded or missing ground wire. Only runs and revs when the rear brake lever is the give away for this one. It's like this...the back brake is cable operated so in the absence of proper ground wires...pulling the rear brake lever back closes the brake switch contacts and creates a ground that then travels through the brake lever...down the brake cable to the rear brake drum. The brake drum is part of the frame..so now you have created your missing or corroded ground. You should have 2 ground wires. One is a frame ground and one is an engine ground. Both must be intact. So verify that you have a good and present frame ground as well as a good and present engine ground wire. Sounds way out there and crazy huh? Trust me on this one and check for both a frame and engine ground wire...also make sure they have good contact and are not corroded. Check both ends of both ground wires for corrosion. As always..my disclaimer--> I am a retired military Combat Medic..a Paramedic...Cardiac Tech and Nurse. I no longer do any of that cause I got burned out in the medical field. So now I live off of my military retirement pension and have a small Scooter parts/repair business. I am not an ASE certified mechanic...but I do work on customers Scoots a bunch. Check all the above ground issues out and if I am wrong...rub it in my face and I will buy ya lunch. But I sure hope yer not hungry..cause this is gonna fix your problem..and so yer gonna go hungry. But hey..at least yer Scoot is gonna run for ya.. Please don't take me as a smart @ss or cocky..folks here know me well and know I have an odd sense of humor. Let us know what ya find..but that outta get ya up n running.. Glenn
Post by themajekalbum on Aug 19, 2014 23:38:14 GMT -5
My 05 vitality doesn't have a ground strap to the frame or harness. Its never given me any funky issues like he's experiencing. Now you got me wondering where my motors getting it's ground from. Guess I'll add one when I re-install my motor for piece of mind.
Post by kymcopurvis1 on Aug 20, 2014 4:23:59 GMT -5
Thanks for the speedy replies guys I'm at work at the moment but will definatly be doing that when I finish I'll let you know how it goes!
Post by usmcdoc on Aug 20, 2014 16:09:55 GMT -5
Thanks for the speedy replies guys I'm at work at the moment but will definatly be doing that when I finish I'll let you know how it goes! Any word yet? The suspense is killing me.. Glenn
Post by kymcopurvis1 on Aug 22, 2014 3:19:19 GMT -5
Hhaha not yet glen the weather's not been to pleasant the last couple of days so haven't got round to anything yet Hopfully tomorrow I'll have word when I've got a full day also :-D
Jack
Post by 2strokd on Aug 22, 2014 14:39:38 GMT -5
umc is right. My uncle did some work to him Cobra. Removed the starter components.. Well, with that was the main ground for the engine. When he started it it was missing and studering but when he hit the rear brake it shocked him and off he went lol. It was classic! A great laugh we got that day!
Thats a great scooter! It has the SF10 style engine as themaj mentioned. Same as the Cobra Racer. The only real diffs are wheels and some other smalls. Handgaurds, hocky mask headlight.. The Cross is a more of "Enduro" style scoot. They are very reliable and will run 45-50MPH in stock trim and get 60-80MPG. With slight mods and taller gears they will pull 55-60MPH or more no problem.
Ive got some parts around if you need anything.
Post by kymcopurvis1 on Aug 23, 2014 11:25:12 GMT -5
Afternoon lads just went out to start the scooter and the bloody thing now won't start don't know. If it could be down to the rain over the past few days just seems strange I've got a spark carb is getting fuel through nicely any ideas?
Post by kymcopurvis1 on Aug 23, 2014 15:21:20 GMT -5
False alarm haha must be because it hadn't been started for a few days chucked some fuel down the barrel and it's running also bought a new ignition coil fitted that and it seems to be running a lot better going to earth everything out tomorrow and Hopfully that sorts it starting a build thread aswell with pictures so check it out see what you think! :-)
Post by kymcopurvis1 on Aug 24, 2014 9:37:20 GMT -5
Earthing worked an absolute dream guys idles fine and rev all. The way to about 8 and a half thousand revs no problem don't even need to hold the rear brake in anymore ha
Post by usmcdoc on Aug 24, 2014 10:30:38 GMT -5
Earthing worked an absolute dream guys idles fine and rev all. The way to about 8 and a half thousand revs no problem don't even need to hold the rear brake in anymore ha ahyigamii negnai aseechie bosa gogankiii.. (I told you Brit.. we Chippewa are not stupid...we are just underrated) It was a ground/earth issue huh?
Post by kymcopurvis1 on Aug 24, 2014 12:45:17 GMT -5
Yes mate haha it was the starter motor ground that was causing the problem I've just left it ticking over for about 30 mins and it never spluttered or cut out once I even disconnected the rear brake and it still ran perfect thanks :-)
Post by usmcdoc on Aug 24, 2014 15:01:15 GMT -5
Yes mate haha it was the starter motor ground that was causing the problem I've just left it ticking over for about 30 mins and it never spluttered or cut out once I even disconnected the rear brake and it still ran perfect thanks :-) And you think I was wrong? Mate as me dad would say cause he is a brit. and me mum is a Chippewa.. I would think only here in states people would not believe an Injun.. Glad you it fixed my brother nagamii itahsa sesa.. Glenn
