Post by blissscoot on Aug 19, 2014 21:00:33 GMT -5
Have a Retro-4 cycle 50 QT that is pumping oil from hose on the ground when running. Checked oil level again and empty. Filled and after a ride or two, did the same thing. Hose is from the front of motor. Wondering if this is a major or minor problem. Would appreciate any in site to the problem! THANKS
Post by niz76 on Aug 19, 2014 21:02:06 GMT -5
Sounds pretty major to me!
Post by blissscoot on Aug 19, 2014 23:10:13 GMT -5
Thanks, afraid of that. I'll wait on other idea's/comments! Hoping I can fix somehow.
Post by usmcdoc on Aug 19, 2014 23:10:41 GMT -5
This is more common on the 150cc engines..but when it occurs it is due to 'blow by' of the piston...rings or a combination of both. The compression stroke blows by the piston...where those gases go down into the crankcase. This pressurizes the crankcase forcing oil up and out of your breather tubing on the head of the engine. Normally on the 50cc engines when there is blow by...the engine does not have enough compression to run. But I have seen 2 that did run with that blow by..and both spewed oil out of the vent tube. Of course I am assuming you mean the tubing that comes from the engine head?
Post by blissscoot on Aug 21, 2014 23:07:39 GMT -5
I believe it is coming out of the engine head. I set the job aside for now until I have more time but wanted to thank you for the info. If I were to take it down I will need a manual and a place for parts. Thinking I will look for that too. Retro -4 STCQT-50, Engine 139QMB built 2004. Have any places to look?
Post by scooterpimp on Aug 22, 2014 19:03:42 GMT -5
BBK will fix it & make ya happier when you twist the throttle.
nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on Aug 25, 2014 6:03:47 GMT -5
Yep BBK for sure
Post by stevec on Aug 25, 2014 11:59:14 GMT -5
two great things happen, leak is gone and you can go faster, i say go for BBK.
Post by scooterpimp on Aug 25, 2014 18:48:04 GMT -5
Or pull out dipstick & run hose in the hole. (Just kidding)
Post by stevec on Aug 25, 2014 19:13:58 GMT -5
that would work lol! just don't show anyone from china or you will see new scooters coming that way.
Post by blissscoot on Aug 26, 2014 15:38:34 GMT -5
Who is BBK, where and # ?
Post by 2TDave on Aug 26, 2014 17:22:56 GMT -5
Big bore kit.
Post by salmilo1 on Sept 10, 2014 12:14:21 GMT -5
