Post by huflungdung on Aug 20, 2014 11:16:02 GMT -5
I have a Tao Tao 150 powermax (12" wheels) which came with a Chinese 835 belt. Can I use an 842 ? CVTs are new to me, and they seem a little magic - I would expect them to eat belts.
What would be the practical differences using either of these?
Post by scooterpimp on Aug 20, 2014 18:00:57 GMT -5
I would probably stay with the same # belt , but get a good one like bando or gates.
Post by stevec on Aug 21, 2014 5:04:20 GMT -5
the 842 is slightly longer and is normally used if you have a larger performance variator that the belt would ride higher on, it would affect your take off but give you more top end. i also recommend staying with the stock size and get a bando or gates.
Post by huflungdung on Aug 21, 2014 12:24:13 GMT -5
the 842 is slightly longer and is normally used if you have a larger performance variator that the belt would ride higher on, it would affect your take off but give you more top end. i also recommend staying with the stock size and get a bando or gates. Thank you. That makes good sense.
