Post by scooterpimp on Oct 30, 2014 4:53:32 GMT -5
Buy it & try it.
Post by Deleted on Nov 6, 2014 9:36:27 GMT -5
Compression is not an issue when it runs at all. If it would not start and had spark that would have been in the diagnostics. Some times people people try to over think a problem and go on tangents. BTW, not my first rodeo.
Rodeo? after getting thrown alot you eventually learn how to stay on. No low compression engine gets past me, ever.
Compression Not an issue if it runs at all you say?
A 120 psi 4t scooter engine will often times run great, once you get it running (which is damn near impossible) and compression is very much the issue. A compression test is not a 'tangent' Sir. Knowing and executing proper diagnostic flow and procedure is the professional experienced way. To assume a problem does not exist is the way of the Novice.
Dont ask for 'pearls of wisdom' if you are not willing to listen.
Post by 90GTVert on Nov 6, 2014 12:05:04 GMT -5
It sounded to me like it would not create a spark once it heated up. I don't understand how checking compression is the professional experienced way if you have no spark. I don't claim to be a pro, but I have never once checked compression because I had no spark or spark stopped once the engine was hot.
Post by scooterpimp on Nov 6, 2014 19:01:42 GMT -5
Post by Sitticuss on Nov 7, 2014 19:47:41 GMT -5
Post by craisin on Nov 7, 2014 23:19:36 GMT -5
Post by Deleted on Nov 8, 2014 0:34:18 GMT -5
It sounded to me like it would not create a spark once it heated up. I don't understand how checking compression is the professional experienced way if you have no spark. I don't claim to be a pro, but I have never once checked compression because I had no spark or spark stopped once the engine was hot. i didnt see where he said he had no spark I only read the very first post made Oct 24, 2014 at 9:00am
Post by craisin on Nov 8, 2014 5:23:42 GMT -5
Post by Sitticuss on Nov 8, 2014 6:54:21 GMT -5
Post by 90GTVert on Nov 8, 2014 8:29:59 GMT -5
I feel like I'm in a movie theater with all of this popcorn.
Post by Sitticuss on Nov 8, 2014 8:52:00 GMT -5
Post by 90GTVert on Nov 8, 2014 11:44:13 GMT -5
Post by katastroff on Nov 8, 2014 12:49:59 GMT -5
Post by 90GTVert on Nov 8, 2014 13:57:53 GMT -5
I win. Locked.
