Post by oldgeek on Feb 11, 2015 13:30:33 GMT -5
I just pulled the trigger on the BWS 100 Variator and TD from autotech, $203.90 shipped. I just had him invoice me through paypal, no sense paying all the fees to Feebay, although he still has to give PayPal (also owned by feebay) some of that money.
If I get any gains at all in the takeoff or topend I think it will be worth it. Now I need to find a suitable belt to use with it. I have the belt for the Malossi OR kit I got over the holidays. I will likely give it a try first.
Post by 90GTVert on Feb 11, 2015 15:17:15 GMT -5
Nice! Looking forward to seeing how this works out.
Post by moofus02 on Feb 11, 2015 15:35:54 GMT -5
I just pulled the trigger on the BWS 100 Variator and TD from autotech, $203.90 shipped. I just had him invoice me through paypal, no sense paying all the fees to Feebay, although he still has to give PayPal (also owned by feebay) some of that money. If I get any gains at all in the takeoff or topend I think it will be worth it. Now I need to find a suitable belt to use with it. I have the belt for the Malossi OR kit I got over the holidays. I will likely give it a try first. You putting that in a longcase clone or a Zuma motor? Sent from my SPH-L720 using proboards
Post by oldgeek on Feb 11, 2015 16:41:17 GMT -5
I just pulled the trigger on the BWS 100 Variator and TD from autotech, $203.90 shipped. I just had him invoice me through paypal, no sense paying all the fees to Feebay, although he still has to give PayPal (also owned by feebay) some of that money. If I get any gains at all in the takeoff or topend I think it will be worth it. Now I need to find a suitable belt to use with it. I have the belt for the Malossi OR kit I got over the holidays. I will likely give it a try first. You putting that in a longcase clone or a Zuma motor? Sent from my SPH-L720 using proboards I am going to put it in the 99cc short case build in the vento zip Sent from my SGH-T999 using proboards
Post by moofus02 on Feb 11, 2015 16:51:58 GMT -5
Cool i would guess the overrange belt will be close to the right length
Post by niz76 on Feb 11, 2015 18:18:52 GMT -5
I have a Piaggio Rear pulley and was thinking of making a "poor man's overrange" but I can't seem to find any belts long enough to make it all work in this Adly... moofus02, do you know if anythings available?? Sorry to hijack your thread Oldgeek- I'm trying to assemble a OR inexpensively also!
Post by oldgeek on Feb 11, 2015 19:33:14 GMT -5
I have a Piaggio Rear pulley and was thinking of making a "poor man's overrange" but I can't seem to find any belts long enough to make it all work in this Adly... moofus02, do you know if anythings available?? Sorry to hijack your thread Oldgeek- I'm trying to assemble a OR inexpensively also! No worries, would be nice to find cheaper alternatives to high end, high price. As a side note, I opened up my malossi rear pulley today from its original sealed package, and I am amazed at the poor quality weld on the pulley! Seriously, the robot welder was hung over or something. They had to grind part of the weld off by hand, it was that bad. I will post a picture here ASAP. Well the pictures don't really show how bad it looks, but I have never seen a weld this poor on any rear pulley. Even the welds on a cheap stock pulley look way better than this. The weld had to be ground down in 3 places at the factory. I am VERY disappointed.
Post by niz76 on Feb 11, 2015 20:29:54 GMT -5
I recently opened up the CVT cover of the Daelim Cordi (Honda DIO clone) and it just the opposite. I was amazed at the high quality weld on the variator- the kick start pawl is permanantly attached to it- it is one of the most perfect welds I've ever seen! lol. Malossi parts should be top notch for what $$ they charge!
Post by niz76 on Feb 11, 2015 20:31:30 GMT -5
I have a Piaggio Rear pulley and was thinking of making a "poor man's overrange" but I can't seem to find any belts long enough to make it all work in this Adly... moofus02, do you know if anythings available?? Sorry to hijack your thread Oldgeek- I'm trying to assemble a OR inexpensively also! No worries, would be nice to find cheaper alternatives to high end, high price. As a side note, I opened up my malossi rear pulley today from its original sealed package, and I am amazed at the poor quality weld on the pulley! Seriously, the robot welder was hung over or something. They had to grind part of the weld off by hand, it was that bad. I will post a picture here ASAP. Well the pictures don't really show how bad it looks, but I have never seen a weld this poor on any rear pulley. Even the welds on a cheap stock pulley look way better than this. The weld had to be ground down in 3 places at the factory. Jeez- the QA tech needs to be fired! Malossi must be desperate for $$ if they're letting this type of quality slide by... BTW- I thought Malossi stuff was made in Italy??
Post by oldgeek on Feb 11, 2015 20:37:09 GMT -5
No worries, would be nice to find cheaper alternatives to high end, high price. As a side note, I opened up my malossi rear pulley today from its original sealed package, and I am amazed at the poor quality weld on the pulley! Seriously, the robot welder was hung over or something. They had to grind part of the weld off by hand, it was that bad. I will post a picture here ASAP. Well the pictures don't really show how bad it looks, but I have never seen a weld this poor on any rear pulley. Even the welds on a cheap stock pulley look way better than this. The weld had to be ground down in 3 places at the factory. Jeez- the QA tech needs to be fired! Malossi must be desperate for $$ if they're letting this type of quality slide by... BTW- I thought Malossi stuff was made in Italy?? It is, but if you want a decent bearing, go to Germany.
Post by 90GTVert on Feb 11, 2015 23:15:04 GMT -5
Post by moofus02 on Feb 12, 2015 0:19:49 GMT -5
That's the big problem with the adly cases no belt for overrange
Post by niz76 on Feb 12, 2015 15:27:49 GMT -5
Thanks Brent I may just give that crazy looking Gates belt a try... $52.00 wow.
Post by oldgeek on Feb 15, 2015 21:41:08 GMT -5
Tracking says parts should be here Tuesday. I hope I have some time to work on scooters this week!
Post by oldgeek on Feb 16, 2015 17:42:18 GMT -5
WoW! Package arrived today, 1 day early! Blazing fast from Taiwan. Way to go autotech355! However, I failed to realize the variator does not come with a bushing. Furthermore neither bushing I have for the Malossi OR kit will fit the BWS 100 variator. One is to big, and one is too small. All of this brings me to another realization, the kit I bought to convert the malossi OR variator to large spline is the wrong one. Anyway I am going to the warehouse a little later, and I will see what I can sort out. I will post some better pictures tonight.
