Post by thatcrazyguy on Jul 16, 2015 14:38:12 GMT -5
Thank god i still had the connection for the stock airbox, scoot tuning had this filter able to connect to a 32-35 mm and i doubt it was bigger than 28mm!!! But i think it looks badass coming out off the carb like i have it!! Still looking for around a 68" drum break cable!!! No luck so far
Post by Availien on Jul 16, 2015 15:06:05 GMT -5
Can you run the cable a different route to make up for the slack? I had to do that. Instead of coming under the scooter from where it was originally, I just went to the other side and then run to the tire.
Post by thatcrazyguy on Jul 16, 2015 15:43:45 GMT -5
Can you run the cable a different route to make up for the slack? I had to do that. Instead of coming under the scooter from where it was originally, I just went to the other side and then run to the tire. I have more beer in me now and am running to store for more! When i come back i will attempt this method!!!!
Post by Availien on Jul 16, 2015 16:09:11 GMT -5
Can you run the cable a different route to make up for the slack? I had to do that. Instead of coming under the scooter from where it was originally, I just went to the other side and then run to the tire. I have more beer in me now and am running to store for more! When i come back i will attempt this method!!!! You could just install the cable how it's supposed to be, adjust the brake so it feels good, and then push the slack somewhere. As long as it doesn't get in a bind, it should be ok.
Post by thatcrazyguy on Jul 16, 2015 18:22:07 GMT -5
I have more beer in me now and am running to store for more! When i come back i will attempt this method!!!! You could just install the cable how it's supposed to be, adjust the brake so it feels good, and then push the slack somewhere. As long as it doesn't get in a bind, it should be ok. It ended up getting in a very bad bind and seems unrideable... Well rideable but i doubt itll stop me if i need to go from 40mph to 0 suddenly. So i dont dare ride the scoot, niz76 can vouch for how crazy the pinellas/pasco drivers are!!!!! So i connected carb up, will get check tomorrow and pick up a spark plug, finish putting it back together and get her running and take her around the block to give her a good tune and order a brake cable!!! All i can find is a 72" cable which is same i have now, so ill order that and re-route the cable so itll be tight and stop!!!!!
Post by thatcrazyguy on Jul 17, 2015 12:51:36 GMT -5
BR8HS or BR8HIX works fine for me. Whats the difference??
Post by thatcrazyguy on Jul 17, 2015 13:12:51 GMT -5
I picked up 2x of the br8hs plugs!! At dmv now switching addresses on my registration and then gonna go home and put the scoot together and get her to start!!
Post by thatcrazyguy on Jul 17, 2015 20:11:00 GMT -5
Post by oldgeek on Jul 17, 2015 20:22:27 GMT -5
IMHO What you have now is better than that carb.
Post by thatcrazyguy on Jul 17, 2015 20:32:06 GMT -5
IMHO What you have now is better than that carb. I have a leader carb but the throttle engle is stripped and holds no slack ob n the cable so i needed a new temporary carb til i find anther job
Post by thatcrazyguy on Jul 18, 2015 14:53:12 GMT -5
Whoop!!! Today before i Started pouring i went downstairs and attempted to start the scoot, couldnt get her to start yesterday and figured id need to check compression, but.... She started first kick today and bogged for the whole 2 seconds she ran then cut off. I kick a few more times and she started!!! I have a 105mj in it open filter and along with no throttle response cuz carb fucked up. New cheapo carb should arrive tuesday or wednesday then ill tune that baby in good and be ridin!!! Then its on to niz76 house to ride around town with him when were both free! Im off wednesday for court and meet with probation officer to pass yet another drug test!!! So the carb will get installed than quite possibly
Post by thatcrazyguy on Jul 18, 2015 14:55:25 GMT -5
Also, about 5 weeks ago i got a new iphone 5s, i love it but damn am i glad to say I bought the tempered glass cover for it, i dropped vice grips on the phone, stepped on it with my heel, and dropped the alan wrench on it all while workin on my scooter a handful of times!!! Whats next? Run jt over probably when i get her running!!!
Post by thatcrazyguy on Jul 18, 2015 15:50:53 GMT -5
So i remember i had the air inlet screw on the carb all the way in, i screwed it just about all the way out and still conplete bog so ill start from a 100mj and work my way down with the new carb!! Will probably end up with a 90 but i dont want to go straight to a 90 and its too lean!!!
Post by Corrosion on Jul 18, 2015 16:18:34 GMT -5
Air box will likely solve your problems.
Post by thatcrazyguy on Jul 18, 2015 16:40:07 GMT -5
Air box will likely solve your problems. -.- learn to read my books
