Post by 190mech on Jul 18, 2015 19:25:49 GMT -5
Ive run a modded stock airbox on 125cc MX topends with good results,just cause it has "stock" in doesnt mean its BAD!!
Post by thatcrazyguy on Jul 18, 2015 19:43:55 GMT -5
Ive run a modded stock airbox on 125cc MX topends with good results,just cause it has "stock" in doesnt mean its BAD!! There is no place to mount the airbox... Unless i bungee cord is around the shock lmfao
Post by thatcrazyguy on Jul 18, 2015 19:45:00 GMT -5
Ive run a modded stock airbox on 125cc MX topends with good results,just cause it has "stock" in doesnt mean its BAD!! Anyways, i like the extra sound of the open air filter since i dont have a loud badass pipe i have a jet kit just waiting on new carb to tune
Post by 190mech on Jul 18, 2015 20:09:05 GMT -5
Ive mounted my 'stock' airbox BEHIND the rear shock and used a length of flex hose to attach it to the carb.. You like a loud intake?I like a motor that is easy to tune and makes its best power(read stock airbox)...Here is an early one in front of the shock; 49ccscoot.proboards.com/thread/497/airbox-relocation
Post by thatcrazyguy on Jul 18, 2015 20:59:50 GMT -5
Ive mounted my 'stock' airbox BEHIND the rear shock and used a length of flex hose to attach it to the carb.. You like a loud intake?I like a motor that is easy to tune and makes its best power(read stock airbox)...Here is an early one in front of the shock; 49ccscoot.proboards.com/thread/497/airbox-relocationI have a rear facing carb and the airbox has a metal bracket that mounts to the left and right of the shock mount, but the shock mount is located in a different spot and with no spot to mount the airbox.
Post by 190mech on Jul 19, 2015 3:34:21 GMT -5
Post by oldgeek on Jul 19, 2015 7:12:12 GMT -5
I ran into the same problem with my zip. Here are a couple solutions I came up with.
Post by thatcrazyguy on Jul 19, 2015 9:01:22 GMT -5
I ran into the same problem with my zip. Here are a couple solutions I came up with. How did you mount the airbox on the bottom pic??
Post by oldgeek on Jul 19, 2015 10:41:06 GMT -5
The airbox had a couple round metal standoffs. I lined one up with a bolt for the CVT cover, (I had to use a much longer screw) and the other one I cut short and used a piece of flat aluminum to make a simple bracket to reach another CVT bolt.
I am going over to the warehouse later I will try to get a picture for you, since the zip is disassembled anyway.
Post by thatcrazyguy on Jul 19, 2015 11:43:49 GMT -5
The airbox had a couple round metal standoffs. I lined one up with a bolt for the CVT cover, (I had to use a much longer screw) and the other one I cut short and used a piece of flat aluminum to make a simple bracket to reach another CVT bolt. I am going over to the warehouse later I will try to get a picture for you, since the zip is disassembled anyway. Ok thanks boss. Ill probably just go ahead and attempt to tune the new carb with the open air filter and if it seems almost impossible ill figure out how to get the stock box mounted!
Post by thatcrazyguy on Jul 19, 2015 16:33:09 GMT -5
@19mech. How much do u charge for your peace pipes uou make? 90cc engine and the minarelli horizontal top end
Post by thatcrazyguy on Jul 20, 2015 12:57:17 GMT -5
Ran into some troubles... I fired her up with the front tire up against the wall since i have no brakes, pulled in the theottle cable to rev her up and the cvt started smoking really bad!! Opened it up and the cvt was well over 200 degrees... I took a video but youtube wont upload it for some reason :/
Post by thatcrazyguy on Jul 20, 2015 12:58:24 GMT -5
Post by 90GTVert on Jul 20, 2015 22:22:29 GMT -5
You'll need to pop the cover off and have a look, but my guess is your tire had more traction than your belt so basically you did a burnout with your belt instead of with the tire.
Post by thatcrazyguy on Jul 22, 2015 12:54:46 GMT -5
Tracking the carb and itll be here tomorrow, arrived at my local post office a few hours ago! Havent messed with it past couple days, sons been sick since Sunday, i left work early yesterday because i just couldnt deal with the pain my body was in and i stayed home again with my son today. Maybe tomorrow ill be feeling better to work and fix the scoot!!!!
