Post by redneck on Jun 1, 2015 17:38:12 GMT -5
Yah mines gonna have blinkers front and rear rear brake lights I have 2 led headlight but not gonna have any real storage just gonna carry a back pack
Post by redneck on Jun 2, 2015 19:57:51 GMT -5
Post by Deleted on Jun 2, 2015 20:07:01 GMT -5
Whew! Looking gooood!
Post by redneck on Jun 3, 2015 15:18:32 GMT -5
got my diamond plate flor pan mounted
Post by katastroff on Jun 3, 2015 16:56:27 GMT -5
Going nicely!!!!
Post by 90GTVert on Jun 3, 2015 18:34:33 GMT -5
Neat build and moving along quite quickly. Good work.
Post by redneck on Jun 3, 2015 18:56:05 GMT -5
thank you guys but now im doing my least favorite part the mock up wiring and I ran into a problem the three prong plug coming out of the stator has no green wire coming out of it it has a white and a yellow there was two other wires a red with a black strip that I know goes to the cdi then a blue with a white strip that im not 100% sure but I think it also goes to the cdi is my stator missing a wire? in the picture I have the white with a blue strip hooked up to a yellow with a blue strip they were both cut so I figured that's were it went
Post by redneck on Jun 3, 2015 20:01:47 GMT -5
or is it wired right and then do I need to ground the geen wire in the other side of the conector
Post by 90GTVert on Jun 4, 2015 7:34:58 GMT -5
Some stators don't have a ground wire, usually green. Red/black is the exciter coil, charging power to CDI. The blue/white or blue/yellow should be the pickup trigger signal to the CDI. White and yellow are charging and lighting power.
Post by redneck on Jun 4, 2015 19:18:32 GMT -5
ok thank you well I got my wiring together enough to try to turn it over first problem I realized is the lights are on as soon as I turn the key on second problem is I got no spark unfortunately my battery died and my gf has my truck and my battery charger is in it so ill have to wait till tomorrow to start chasseing some problems but it does turn over and my brake lights and blinkers work so im happy for now electrical is ugly right know ill slowly start to clean it up
Post by redneck on Jun 4, 2015 19:22:43 GMT -5
rear end looks crooked in pictures but is not bolted in
Post by katastroff on Jun 4, 2015 20:47:40 GMT -5
You're cheating!!! you got a mechanic!!!!
Post by redneck on Jun 4, 2015 20:52:33 GMT -5
lmfao she's a pro
Post by scooterpimp on Jun 4, 2015 20:53:06 GMT -5
I think She's the quality control inspector.
Post by redneck on Jun 4, 2015 20:57:08 GMT -5
lol she asks me every day after work if were going to work on the scooter shes my motivation
