Post by crutchfieldcreations on Jun 30, 2015 15:37:31 GMT -5
I found it on partsforscooter.com. do u think it b will give me more power, and what do you know about jetting the carb,and new air filter, will keep it from freezing up.
Post by 90GTVert on Jun 30, 2015 15:44:00 GMT -5
Single ring pistons reduce friction and are good for high rev engines. Single rings need to be replaced more often and you may lose a little low rev output. If this is a 10,000+ RPM scoot then go for the single ring if you'd like, but for a more typical street/sport build you may want to find a dual ring.
Post by crutchfieldcreations on Jun 30, 2015 16:03:43 GMT -5
Yeah its an everyday ride so i will go with the dual ring, so what about jetting the carb and aftermarket air filter, when I removed my spark plug it was a grayish color
Post by 90GTVert on Jun 30, 2015 16:20:44 GMT -5
I prefer a stock or modified stock air box, but if you use an open filter start with a jet about 20-25% larger than what you used with a stock air box.
Post by Elektrey on Jun 30, 2015 16:23:23 GMT -5
Yeah its an everyday ride so i will go with the dual ring, so what about jetting the carb and aftermarket air filter, when I removed my spark plug it was a grayish color someone correct me if I'm wrong, but this is the kind of color I look for:
Post by crutchfieldcreations on Jun 30, 2015 18:46:53 GMT -5
This is what the plug and piston looks like after it froze on me
Post by stuckchuck on Jun 30, 2015 18:54:07 GMT -5
Post by crutchfieldcreations on Jun 30, 2015 20:05:18 GMT -5
Do u think I can reuse this piston
Post by crutchfieldcreations on Aug 12, 2015 16:18:11 GMT -5
How do i know which way i install my piston. On the bottom of the piston one side is flat and tje other side has like a port or groove on it
Post by frank50e on Aug 12, 2015 18:02:29 GMT -5
Top of piston has arrow
Post by frank50e on Aug 12, 2015 18:03:49 GMT -5
IF not ports match intake
