Post by damari on Jun 8, 2015 11:23:23 GMT -5
Hey guys, Bought a new Peugeot Speedfight 3 and it seems that on these new scooters only one headlight can be turned on at a time. I know it is supposed to be that way, but I don't like it. Amy suggestions on the best way to switch on both of them? If I change the connection directly on the switches are the cabling,the switch and the fuse able to conduct the additional load without any problems? Or should I change some or all of them?
Post by thatcrazyguy on Jun 8, 2015 11:58:52 GMT -5
Hey guys, Bought a new Peugeot Speedfight 3 and it seems that on these new scooters only one headlight can be turned on at a time. I know it is supposed to be that way, but I don't like it. Amy suggestions on the best way to switch on both of them? If I change the connection directly on the switches are the cabling,the switch and the fuse able to conduct the additional load without any problems? Or should I change some or all of them? 49ccscoot.proboards.com/thread/8534/dual-headlight-system-modification
Post by stevec on Jun 20, 2015 5:43:02 GMT -5
be careful when modifying the headlights. if they draw too much current your stator won't be able to keep the battery charged.
Post by scooterpimp on Jun 20, 2015 13:59:04 GMT -5
Stevec , has a good point. Been down that road with a scoot i worked on last month. Had dual headlights he replaced bulbs because one blew. & had charging issues & dim lights ever since . Come to find out he put 2 -35watt bulbs in place of 2 - 18watt bulbs which doubled the draw on system. Went from 36 to 70 watt draw. Changed his bulbs to identical bulbs , but in 18watt. Charging was better & lighting was brighter.your charging system etc. May differ.
