Post by 90GTVert on Aug 5, 2015 15:11:33 GMT -5
Thanks for that. I moved it into the Tech Library.
Post by ryan_ott on Aug 5, 2015 18:17:33 GMT -5
Thanks for that. I moved it into the Tech Library. No problem. Using those adapters is soooo much easier then trying to drill out a spark plug. I believe you may be able to find them is different plug sizes. The 14mm should be available locally.
Post by spaz12 on Aug 10, 2015 13:56:03 GMT -5
Updates?
Post by ryan_ott on Aug 10, 2015 22:03:18 GMT -5
I'm out of town now, I'll get some progress when I get back next week. I have to re check my timing but it starts first kick cold so it should be really close. I tried a 138/45 and I couldn't make it out if the driveway. i worked down to a 125 so I could at least get around the block. I need to go a little leaner. Seems lite to me but I'm used to the bigger AC 103cc motors. I still have work to do when I get back.
Post by iwiketuddlz on Aug 11, 2015 7:47:47 GMT -5
Mmmm?? 125?? Darn I run a 120 in my 28mm keihin and it's perfect with the alien eye Doppler filter I run on the 94cc EVO....
Post by ryan_ott on Aug 12, 2015 8:33:07 GMT -5
Post by iwiketuddlz on Aug 12, 2015 13:03:10 GMT -5
Yes sir that's it!!!! I love that filter it's nice and quiet but still gets the 94cc plenty of air it needs!!!!
Post by spaz12 on Aug 12, 2015 18:18:40 GMT -5
The ad says ...for dellorto PHBG carburetors Will that fit your 28 mm carb?
Post by iwiketuddlz on Aug 12, 2015 20:10:37 GMT -5
No it will not fit the keihin I bought and 90 degree adaptor for the keihin carb and it fit right inside the filter and behind my plastic perfectly!!!! Maybe you can do the same if you get that filter that is......
Post by ryan_ott on Aug 15, 2015 17:09:07 GMT -5
Post by ryan_ott on Aug 15, 2015 17:10:09 GMT -5
The ad says ...for dellorto PHBG carburetors Will that fit your 28 mm carb? I got the filter figured out, I just needed an adapter. Waiting for me when I got home.
Post by iwiketuddlz on Aug 16, 2015 14:42:56 GMT -5
Woot awesome man ..... Now let's see that sucker do some wheelies!!!!! Woot woot gots love the sound of high end LC cylinders!!!!
Post by ryan_ott on Aug 16, 2015 16:43:19 GMT -5
I need to make a partial degree wheel to mount up to figure my degrees of timing, my plug says I'm to far advanced the electrode is discolored back kind of far. I haven't been able to get more then 150 deg of temp, not even 200 on the plug. I'll get there...
Post by 190mech on Aug 16, 2015 17:34:21 GMT -5
Post by iwiketuddlz on Aug 16, 2015 19:28:51 GMT -5
Ha dude!!! Awesome !!!!!ha you sir are one intelligent individual!!!!!! How did you get your marks??? With a piston stop to set TDC??? Ima make one of those.....
