Post by 90GTVert on Jul 2, 2015 11:18:37 GMT -5
Post by sai on Jul 9, 2015 14:14:48 GMT -5
Btw, I finally got around to changing the packing on the silencer with the fmf sheet, so easy to put on tough to take the original apart. This is how it looks like
Post by sai on Jul 11, 2015 17:18:32 GMT -5
Ok, this is ridiculous... I just replaced the Piston Rings and it was running with good compression the past week and now compression is at 90 and I'm losing power from 20-30 and tops out at 35mph on flat.
I was told that it could be because my main is too lean and my pilot is too rich causing an overheating of the cylinder and warping it ever so slightly.
Suggestions?
Post by 190mech on Jul 11, 2015 17:24:53 GMT -5
90 is low..Did you check the ring end gaps?Perhaps the rings are an incorrect size...Did ya 'hand hone' it??
Post by Elektrey on Jul 11, 2015 17:38:28 GMT -5
if your main is lean and it is overheating you will most certainly see it seize.
Before my engine seized from a lack of cooling it ran 100% fine all the way up to the point it seized. I was going about 50mph when it seized too. Then again it was an alum cyl so maybe cast iron cyl is a bit different?
Post by triesandluth on Jul 11, 2015 17:46:27 GMT -5
Some rings have a top and bottom that are ever so slightly different and can create blow by if backwards or upside down. My mallossi kit didn't have markings on the rings though and I still haven't had an issue.
Post by sai on Jul 11, 2015 17:47:40 GMT -5
90 is low..Did you check the ring end gaps?Perhaps the rings are an incorrect size...Did ya 'hand hone' it?? I need to learn how to do it, but I did NOT hand hone it before hand. I do now to a degree with 220 sand paper and didn't make a difference... Unless I REALLY have to press on the sandpaper?
Post by sai on Jul 11, 2015 17:49:40 GMT -5
if your main is lean and it is overheating you will most certainly see it seize. Before my engine seized from a lack of cooling it ran 100% fine all the way up to the point it seized. I was going about 50mph when it seized too. Then again it was an alum cyl so maybe cast iron cyl is a bit different? Yea, It didn't seize... the walls of the cylinder is still very smooth... I finally did the X-hatch sandpaper just now though. I have seized 2 BBKs before and just like you, it seized going WOT or close to it. Engine just died and I see a 4 corner scoring on the piston and cylinder. So I don't know what the heck happened now...
Post by Elektrey on Jul 11, 2015 17:51:31 GMT -5
if your main is lean and it is overheating you will most certainly see it seize. Before my engine seized from a lack of cooling it ran 100% fine all the way up to the point it seized. I was going about 50mph when it seized too. Then again it was an alum cyl so maybe cast iron cyl is a bit different? Yea, It didn't seize... the walls of the cylinder is still very smooth... I finally did the X-hatch sandpaper just now though. I have seized 2 BBKs before and just like you, it seized going WOT or close to it. Engine just died and I see a 4 corner scoring on the piston and cylinder. So I don't know what the heck happened now... idk how much the kits are for the super 8 but there only like $130 for my bike. for peace of mind I would just replace it if I were you, it sounds like it's had enough use. either that or you've got some sort of leak somewhere that's causing low compression
Post by sai on Jul 11, 2015 17:53:20 GMT -5
Let's stick to this thread about this subject and use my newest thread mainly for the CVT and Carb tuning. (thank you for responding to both btw.)
Hmmm... how do I check for leaks?
Post by Elektrey on Jul 11, 2015 17:58:22 GMT -5
put the bike on the stand, idling, and spray around areas like intake, exhaust, etc. anywhere a leak could be with WD40 or starter fluid or something flammable.
if you see any change in the RPM when you spray somewhere, you have a leak there.
Post by sai on Jul 11, 2015 18:01:28 GMT -5
put the bike on the stand, idling, and spray around areas like intake, exhaust, etc. anywhere a leak could be with WD40 or starter fluid or something flammable. if you see any change in the RPM when you spray somewhere, you have a leak there. Is carb cleaner ok? I am out of everything else. RPM as in Bike revs and feels like it goes higher on its own? Also, I was told to inspect the crank seal... I don't even know how to do this. (I have a friend who races scooters in CA who is helping me also)
Post by Elektrey on Jul 11, 2015 18:04:16 GMT -5
yeah carb cleaner will work
it should run pretty smooth at idle, just look for any change in it's running like RPMs rising or running worse or anything like that.
Which crank seal were you told to inspect? both?
I don't know how you can check it other than just visually checking for reside outside of the seals, indicating a leak of some sort
Post by sai on Jul 11, 2015 18:09:12 GMT -5
yeah carb cleaner will work it should run pretty smooth at idle, just look for any change in it's running like RPMs rising or running worse or anything like that. Which crank seal were you told to inspect? both? I don't know how you can check it other than just visually checking for reside outside of the seals, indicating a leak of some sort Yea he told how but it's over my head... he's also a mechanic for a race track for scooters. OH, we did some carb tuning check over the phone, it appears that my pilot is too rich which leans out the main he said. My A/F screw is only 1/2 out and it made no difference with 2 full turns out on idle and I'm spitting white smoke on start up. Anyhow... when I lost this much power is when I was using the old piston rings and compression went to hell. Again, these malossi rings are only 1 week old!! Sigh... $30 down the drain. The whole kit has seen close to 10.000 miles btw
Post by Elektrey on Jul 11, 2015 18:11:50 GMT -5
"my pilot is too rich which leans out the main he said."
I don't really understand how that makes any sense sorry lol
10,000 miles is really good for a 70cc kit.
I'd just replace the whole thing
