Post by hppowdercoating on Jul 8, 2015 17:28:09 GMT -5
Picked up this 84 Spree cheap , had bad motor.. So Project "Little Evil" begins... so so far I stripped it down . Welded in some extra frame Supports.. already had my 4.5" stretch Motor mount made up. Made up a Sq Tube rear shock Mount. Yes it's going to be a Hard Tail setup. i cut and Lowered the Handle bar Stem 1.5". Made up and installed a Disc brake front Fork set up.. Modified both rear Panels to Clear the AF16 Engine. Gave them more of a "Eve Smile" Look.. Trail tech Vapor Stealth installed to replace Stock guages Modified/Made Custom rear Rack . Also modded blinker mounts to sit lower and Almost against the Body.. Engine: 1994 AF16 . After correct Tune it should make 15-20 Hp.. 125cc 54mm bore 52.60mm Stroke 28mm polini Carb V8 Stroker pipe Polini variator Mallosi 3G Clutch Mallosi Race CDI Honda Elite font wheel I modded to run Disc brakes..Bridgestone 2.75-10" Honda Met rear wheel : Michelin S1 90/90-10" More pics and info as I go...
Post by tiny on Jul 8, 2015 17:41:07 GMT -5
Interesting to say the least. But that puppy should move
Post by 190mech on Jul 8, 2015 17:42:16 GMT -5
Ive read about a few of these builds,gotta watch your port durations with this combination..Best I recall a spacer had to be fabbed above the cylinder so the piston would extend above deck height to get reasonable figures..
Post by oldgeek on Jul 8, 2015 18:07:58 GMT -5
Suicide ride! That is sick. Going to build me up one of those AF16 motors eventually.
Post by hppowdercoating on Jul 9, 2015 11:10:31 GMT -5
Took it apart last night and Sand blasted the frame, Handle bars, Controls. Today I Powder coated everything Satin Black..
Post by iwiketuddlz on Jul 9, 2015 11:38:11 GMT -5
Wow a stroke that long it should do a flip!!!! Good luck man can't wait to see it go!!!!! Braaaa braaaaap
Post by thatcrazyguy on Jul 10, 2015 14:47:55 GMT -5
Omg so sexy!!!! Great painting skills boss!
Post by jareeb on Jul 10, 2015 15:40:13 GMT -5
sweet build. looks like we have about the same amount of stretch. but i have a mina engine.
Post by hppowdercoating on Jul 11, 2015 19:47:28 GMT -5
A little Progress.. Painted most of the Body panels Gloss black + clear... Have to wait till next weekend to wet sand and Buff out.. Got a Stock spree Seat & Seat Cover from EBay. Trimmed down the Seat Foam about 1".
Post by hppowdercoating on Jul 16, 2015 12:27:29 GMT -5
Slowly coming together. Waiting on a couple parts. Have to order a shorter front brake hose. Custom Decals should be done this week.
Post by oldgeek on Jul 16, 2015 12:46:23 GMT -5
Looking good! You gonna do any videos of this one for us?
Post by 'O'Verse on Jul 16, 2015 12:52:56 GMT -5
Is there a link I can get of your front forks and disk brakes? I have a spree. And yours looks a lot better than mine without the front fenders in place
Post by thatcrazyguy on Jul 16, 2015 18:24:19 GMT -5
That scoot looks sick!!!
Post by 2TDave on Jul 17, 2015 6:00:46 GMT -5
Another sweet build HP!
Post by hppowdercoating on Jul 17, 2015 6:40:07 GMT -5
Is there a link I can get of your front forks and disk brakes? I have a spree. And yours looks a lot better than mine without the front fenders in place Actually the Forks,Tripple & Brake caliper are off a TaoTao ATM 50. I then welded in the Spree Stem ..
