Post by spaz12 on Nov 1, 2015 1:19:06 GMT -5
I knew from yours that it'd come out looking dope.
Post by moofus02 on Nov 1, 2015 2:49:13 GMT -5
I love white yamaha ' s
Post by tsimi on Nov 1, 2015 2:50:26 GMT -5
No red? White? Our cops drive white Scooters.
Post by spaz12 on Nov 1, 2015 4:19:56 GMT -5
I really wanted red but the panels required too much work, and even then I don't think that they would look good. Besides, I think the white looks pretty good and came out better than expected.
Post by spaz12 on Nov 1, 2015 4:31:29 GMT -5
I sanded it, washed it off and then painted it. What kind of sand paper? My exhaust is starting to build up a lot of rust and would love to clean it up! Um, a couple different kinds and grits. I used one of those sanding sponges, some from an orbital and some from a belt sander (all by hand) I honestly can't remember the grits though. Maybe 600 and 300? It was pretty rough paper. I used Krylon high temperature paint.
Post by iwiketuddlz on Nov 1, 2015 5:44:37 GMT -5
Hey spaz!! What temp paint did you use?? I used some 800 degree clear coat on mine and it burned it right off the first 1ft of the header .....wtf it gets that hot???
Post by strgazr27 on Nov 1, 2015 8:05:55 GMT -5
This is what I use. You do need to follow the curing process for best results. m.autozone.com/paint-and-body/paint-spray-can-and-touch-up/vht-paints-clear-satin-flameproof-extreme-high-temperature-coating/997337_0_0/Description VHTSatin Exhaust Clear Coat High Temp11oz Aerosol Can - Part#SP115VHT FlameProof"! Coating will renew and extend the life of any surface exposed to extremely high temperatures. This unique coating is a matte finish, silicone ceramic base widely used by the automotive industry on exhaust systems and the aerospace industry for jet engines, re-entry vehicles and other high temperature applications. VHT FlameProof"! Coating will withstand temperatures up to 2000F (1093C) and is ideal for use on headers, exhaust systems, or wherever an extreme temperature coating is needed.Temperature: 1300F-2000F (704C-1093C)Applications: Headers, Exhaust Manifolds, Piston Domes, Inside HeadsFinish: FlatDry Time: Curing time required and can be done on or off vehicle (see below)Curing FlameProof"!VHT FlameProof"! Coating only attains its unique properties after correct curing (refer to instructions on the can).On the VehiclePaint must be completely dry before curingRun at idle for 10 minutesCool for 20 minutesRun at idle for 20 minutesCool for 20 minutesRun under normal operating conditions for 30 minutesOff the VehiclePaint must be completely dry before curingHeat to 250F (121C) for 30 minutesCool for 30 minutesHeat to 400F (204C) for 30 minutesCool for 30 minutesHeat to 650F (343C ) for 30 minutesCaution: Do not exceed the temperature of the least heat tolerant component or the base metal.Check out our other VHT products!
Post by ams417 on Nov 1, 2015 12:32:10 GMT -5
You'll have that thing looking sharp in no time flat. Looking around down here in Mexico, the market is dominated by Italika now days. No BWS 100's to be found, so far... How's that vacation going? Hope that you're having a blast! So far so good. The $50 a night condo is way nicer than I would have expected. Headed out to one of my favorite breakfast spots now. Probably won't bring any scooter parts back unless I find something I have to have. My wife totally veto' me taking apart a BWS100 and trying to cram it in two suitcases although I think it might have worked. She puts up with a lot of scooter stuff at home and my frivolous spending habits. When my Stage 6 Pro Rep showed up Thursday I got the hands and the hips stance and a "really?". Maybe I can rent a scooter for the day and ride a little. Not many 50's here. Most are bigger.
Post by ams417 on Nov 1, 2015 12:41:42 GMT -5
From the couch, two bedrooms, wife insisted since we brought the kid.
Post by spaz12 on Nov 1, 2015 12:54:39 GMT -5
The site is not being friendly to my tablet this morning. Tuddlez, I don't know what temp it is. I'm going to work on the scoot later today so I'll let you know tonight.
Ams, nice little room ya got there, hope it's close to the beach.
Post by iwiketuddlz on Nov 1, 2015 14:34:00 GMT -5
Wow that looks nice Ams.!!!..must be nice !!!! Thanks spaz....good sir you are!!! Stargaz thanks for the info!!!
Post by thatcrazyguy on Nov 1, 2015 15:36:49 GMT -5
This is what I use. You do need to follow the curing process for best results. m.autozone.com/paint-and-body/paint-spray-can-and-touch-up/vht-paints-clear-satin-flameproof-extreme-high-temperature-coating/997337_0_0/Description VHTSatin Exhaust Clear Coat High Temp11oz Aerosol Can - Part#SP115VHT FlameProof"! Coating will renew and extend the life of any surface exposed to extremely high temperatures. This unique coating is a matte finish, silicone ceramic base widely used by the automotive industry on exhaust systems and the aerospace industry for jet engines, re-entry vehicles and other high temperature applications. VHT FlameProof"! Coating will withstand temperatures up to 2000F (1093C) and is ideal for use on headers, exhaust systems, or wherever an extreme temperature coating is needed.Temperature: 1300F-2000F (704C-1093C)Applications: Headers, Exhaust Manifolds, Piston Domes, Inside HeadsFinish: FlatDry Time: Curing time required and can be done on or off vehicle (see below)Curing FlameProof"!VHT FlameProof"! Coating only attains its unique properties after correct curing (refer to instructions on the can).On the VehiclePaint must be completely dry before curingRun at idle for 10 minutesCool for 20 minutesRun at idle for 20 minutesCool for 20 minutesRun under normal operating conditions for 30 minutesOff the VehiclePaint must be completely dry before curingHeat to 250F (121C) for 30 minutesCool for 30 minutesHeat to 400F (204C) for 30 minutesCool for 30 minutesHeat to 650F (343C ) for 30 minutesCaution: Do not exceed the temperature of the least heat tolerant component or the base metal.Check out our other VHT products! This is actually what I was going to pick up along with the red engine enamel they have
Post by strgazr27 on Nov 1, 2015 16:54:38 GMT -5
The key, with any of the high temp finishes, especially those that are ceramic based is to properly cure them. We're guys, we don't need directions lol but they're for a reason.
Post by derbiman on Nov 1, 2015 22:51:47 GMT -5
I have a tee shirt that I've had for a long time. I got it at Disney on a trip back when the show " Home Improvement" was popular.It says "Binford Tools" "Real men don't need instructions" Lol
Post by iwiketuddlz on Nov 2, 2015 6:08:44 GMT -5
Ha I used to watch that show when I was kid!!!! The asidtent was hot!!! Can't rem her name though
