Post by iwiketuddlz on Dec 8, 2015 9:33:53 GMT -5
I used toilet bowl cleaner on the evo cylinder once when I seized it and it cleaned it right off the nikasil ..!!!! It's called >>The Works<<<<
Just my 2ct
Post by sjfishon on Dec 8, 2015 11:12:06 GMT -5
iwik;;;;;;;;;;;; did you have to wipe afterwards??
Post by spaz12 on Dec 8, 2015 15:50:52 GMT -5
I've spent the last two days laying on my sofa watching movies. Maybe today will be the day I finish it.
Post by Corrosion on Dec 8, 2015 17:56:08 GMT -5
I'm stuck on "Breaking Bad" on netflix!
Post by FrankenMech on Dec 8, 2015 18:21:44 GMT -5
Toilet bowl cleaner works great for stained coffee pots also...
Post by spaz12 on Dec 9, 2015 0:00:15 GMT -5
So, I've been working on this damn cylinder for a couple hours now and it's going terribly slow. I read the bottle and come to find out this is only 14.4 percent Hydrochloric acid. Pretty tame. I knew something was wrong because there is hardly any smell. Hell, when I was a kid the crap sent me to the hospital for taking a big whiff of it! This does nothing. Ugh. So now I'm soaking small strips of gauze in the acid and placing it on the bad spots. I think it's working? If it wasn't such an expensive cylinder I'd just give up.
Post by spaz12 on Dec 9, 2015 4:11:44 GMT -5
The acid on the gauze seems to be working pretty good. Hopefully it will be more betterer before I go to sleep.
Post by spaz12 on Dec 9, 2015 4:35:49 GMT -5
Next question: Assuming that it comes out nice and smooth, is it worth it to buy a 75 dollar piston and ring set (w/ piston pin) and a 9 dollar gasket set? The cylinder costs 225 dollars right now on scootertuning.com. Of course I'll post some really close up pictures so that anyone could make a better judgement. I've never tried this, so I'm totally clueless
Post by 190mech on Dec 9, 2015 4:41:54 GMT -5
What about using a good quality/cheaper taiwan piston?
Post by frank50e on Dec 9, 2015 8:34:06 GMT -5
190 brings up the direction Id take Spaz.
Post by 50ccthunder on Dec 9, 2015 10:39:44 GMT -5
I would be careful using the works cause it is conbustable.
Post by sjfishon on Dec 9, 2015 11:36:12 GMT -5
frank,,, there is just something wrong with cleaning your coffee pot with toilet::: cleaner, sorry
Post by spaz12 on Dec 9, 2015 16:24:07 GMT -5
That sounds like a better and cheaper solution, but where does a person find the quality Taiwanese Pistons? The cylinder is an MHR Rep. I believe it's a 47mm bore? I'm not sure at the moment, but I'll look it up after doctors appointment.
Post by frank50e on Dec 9, 2015 16:54:39 GMT -5
Spaz I have seen 47mm pistons at Scrappys eBay etc.
Post by frank50e on Dec 9, 2015 16:57:54 GMT -5
And you have scooter work to do just because your sick doesn't mean you can waste time at the dr's
