Post by 2strokd on Mar 14, 2011 11:17:22 GMT -5
I've got my fingers crossed for you. It's really hard to type now. :lol:
sctrdawg
scooter bum
Post by sctrdawg on Mar 14, 2011 14:28:39 GMT -5
WELL GOT THE NEW FLY WHEEL ON AND POWER IS BACK TO NORMAL VERY HARD TO START THOUGH THINKING MAYBE NOT ENOUGH FUEL FOR THE PORT JOB . ANY SUGGESTIONS?
Post by speedy1125 on Mar 14, 2011 14:37:15 GMT -5
What size pilot jet? Sounds to me like you may need to go up on the pilot jet.
sctrdawg
scooter bum
Post by sctrdawg on Mar 14, 2011 14:58:56 GMT -5
don't know yet,once running it idles fine. ?? trying my patience for sure ! i'll check the pilot jet tho and we'll see1 thanks speedy!
Post by 90GTVert on Mar 14, 2011 15:03:09 GMT -5
As he said, prob pilot jet or idle mixture adjustment. If you can't get it straight right away, use the accelerator pump to your benefit. Pump the throttle a couple of times then try starting it.
sctrdawg
scooter bum
Post by sctrdawg on Mar 14, 2011 17:22:43 GMT -5
bout eight mnths ago ,bought a 20mm cvk run tong carb from scrappy dog sctrs. Would you believe the jets aren't stamped any where!! so took the #34 pilot out of original carb and it is easier now! the pilot in the 20mm was clogged ,couldnt even blow or poke a wire out of a bread tie thru it!!!
sctrdawg
scooter bum
Post by sctrdawg on Mar 14, 2011 19:52:02 GMT -5
MAN got the thing screaming again and the danged throttle cable snapped in side the tube/ grip!! life happens!! at least it runs great , even if i cant ride it DAMNIT!~!
Post by 90GTVert on Mar 14, 2011 19:54:23 GMT -5
That sucks, but at least it's an easy fix. Not much to figure out. lol
sctrdawg
scooter bum
Post by sctrdawg on Mar 14, 2011 19:58:38 GMT -5
yep jus t cant afford one right now just spent $300 on parts at slowtertronics(scootertronics) feb 25 and still haven't gotten jack s@#T !!
Post by speedy1125 on Mar 14, 2011 20:39:50 GMT -5
Fuel problem figured out so the rest is just incidentals. Awesome!
sctrdawg
scooter bum
Post by sctrdawg on Mar 14, 2011 22:05:52 GMT -5
just remembered got throttle cable from a junked 150 @ my sweethearts house gnna get it tomorrow!! now if i can just get my new var. ,rim , and tire from slowtertronics(scootertronics) ill be set for a while!!
