Post by milly on May 6, 2021 9:26:39 GMT -5
Air source heating going into our bungalow but not by me.
Post by captincvmn on May 6, 2021 17:06:07 GMT -5
Got my scoot inspected. I’m legal now.
Post by scooternub on May 7, 2021 15:01:02 GMT -5
the screen door would not latch anymore so I took it apart all it needed was a new spring ran to the hardware store got it cut it to the size it's nice and tight now. simple fix. that option of replacing the broken spring saved a lot of money from buying a new door handle.
Post by fuzzyruttin on May 7, 2021 23:34:01 GMT -5
Air source heating going into our bungalow but not by me. THIS! This is beautiful. There is no need to evenly space everything for practical function, but when you do, wouldn't you rather see it in its raw form than cover it up?? Nice attention to detail
Post by milly on May 8, 2021 3:24:33 GMT -5
They don't cover it up fuzzyruttin being as its in the old outhouse of the bungalow. Really efficient plumbers as well all pipes radiators and the set up done in 4 days.Minimal hassle.
Post by captincvmn on May 10, 2021 21:47:50 GMT -5
Tilled my garden today. It’s a fight to get what’s left of my 1977 Ariens Rocket tiller to run for an hour annually. Damn thing weighs around 400 pounds. Everything is cast iron. The original carburetor is gone. I made do with a similar unit and bodged up a throttle to the governor. She does ok for an antique.
Post by captincvmn on May 16, 2021 16:56:37 GMT -5
Paid my 2020 taxes. Really must adjust my withholding. Damn ouch
Post by jloi on May 16, 2021 17:23:40 GMT -5
worked on the truck . figured out why the driver side carpet gets wet under the rubber mat. took off 2 access panels on the firewall and sure enough the one closest to the drain for the top grille was full of leaves and trash . vaccumed and poked with wire , finished up with water hose . next is ujoints and shocks and accelerator cable to cure sticking gas pedal. still trying to identify the cable @ --- www.rockauto.com local auto store quoted $70 + dollars. I hope not. turns out they have a ujoint that fits front and rear for $13. the highlighted one . fast forward 3 hrs- ordered ujoints, shocks and air filter
Post by jbjhillbilly on May 16, 2021 17:44:22 GMT -5
Paid my 2020 taxes. Really must adjust my withholding. Damn ouch Oh yeah! Thanks for the reminder!!
Post by scooternub on May 21, 2021 10:55:31 GMT -5
That time of year, took apart patton fan, cleaned & used 3-in_-1 motor oil to oil the motor.
Post by woodini on May 21, 2021 12:58:43 GMT -5
Post by Deleted on May 21, 2021 20:40:07 GMT -5
I changed a light bulb. Feeling very accomplished. 🤣
Post by milly on May 25, 2021 15:11:05 GMT -5
Chimney pot gone. Plus very little rain for a change.
Post by captincvmn on May 26, 2021 7:02:27 GMT -5
Post by scooternub on May 27, 2021 8:38:01 GMT -5
Not today but yesterday. Put it together, 400lbs tractor bed. Not fun.
