Post by eclark5483 on Jul 16, 2016 19:11:58 GMT -5
Too true on the jet. I guess what I am wondering, and I don't think it has been stated. What all did the guy who put the BBK in it do to it when he installed it? Was a new carb added? Were the jets upgraded? Or did he just install the BBK and call it good? Clearly there is an aftermarket pod filter on it. Do you possibly have a link to where the kit was purchased and what all came with it? 100cc BBK is alot of engine to crank too, have you considered going with the high torque starter? As much as your beating on it by holding it down till it starts, I'm shocked you haven't burn it out already. I seriously CRINGED when I watched the video of you starting it. My sympathy's to the starter.
Post by floyd2133 on Jul 16, 2016 21:36:53 GMT -5
In the video the scooter stayed running as long as throttle is pulled. Son as I let go it dies out. I will try to clean the carb. When they had the bbk only thing was in it was the engine. So they installed a 100cc top end, 20 carb.
Post by floyd2133 on Jul 16, 2016 21:37:26 GMT -5
Tonight I guess I will adjust valves then clean carb
Post by floyd2133 on Jul 16, 2016 21:51:44 GMT -5
Just an update It cranks fine with kickstart but won't stay running unless throttle pressed. I bought a multimeter to test battery it's reading 12 volts. However oriellys said it's a bad battery. I'm going to take it to autozone and see their opinion on the battery. But it won't crank with push start only kick. Here is video link to me starting it. It started with push on the video but it won't start that way anymore only kick . But it won't stay running without throttle pressed youtu.be/bwidZ9vyyZo
Post by Deleted on Jul 16, 2016 22:35:03 GMT -5
Just an update It cranks fine with kickstart but won't stay running unless throttle pressed. I bought a multimeter to test battery it's reading 12 volts. However oriellys said it's a bad battery. I'm going to take it to autozone and see their opinion on the battery. But it won't crank with push start only kick. Here is video link to me starting it. It started with push on the video but it won't start that way anymore only kick . But it won't stay running without throttle pressed youtu.be/bwidZ9vyyZoJust so you know, voltage is no indication of the condition of a lead acid battery. It has to be hit with a load like from a battery tester. This will expose a bad cell if there is one. Any auto parts place that sells batteries will have a tester and test your battery for free. If Oriely's tested it and said it is bad...it is bad. Bill
Post by floyd2133 on Jul 16, 2016 23:22:16 GMT -5
Post by arkie on Jul 16, 2016 23:30:43 GMT -5
Larger pilot jet.................
Post by floyd2133 on Jul 16, 2016 23:31:24 GMT -5
I'm begging to think I need new lines however I can not see any rupture in the line from the pet ok to the carb. I'm puzzled I will adjust valves see if that does it .oo3 and .005 and let you all know
Post by floyd2133 on Jul 17, 2016 1:06:35 GMT -5
I adjusted valves still same problem. It starts good. It only stays on with throttle pulled. After throttle relase it dies
Post by floyd2133 on Jul 17, 2016 1:31:52 GMT -5
I see slight moisture on my intake valve can this be why is starts but dies after throttle release? But why would it crank if it wasn't getting fuel?
Post by Deleted on Jul 17, 2016 3:39:29 GMT -5
Perhaps you have water contaminated fuel? That would cause the symptoms you have. Drain some fuel from the line into a clear container and let it sit to see if you can see cloudiness or the water sitting on the bottom of the container.
Bill
Post by floyd2133 on Jul 17, 2016 10:10:54 GMT -5
I started it today adjusted idle and it ran fine. Thanks for all the help guys. I'm sure I will be back
Post by floyd2133 on Jul 17, 2016 10:49:44 GMT -5
Post by arkie on Jul 17, 2016 11:07:07 GMT -5
There are larger sets that include more sizes for $5-$8. Also I would suggest getting a pilot jet set as well. They are very cheap if you get them from China and you will know that you have it covered no matter what.
Post by floyd2133 on Jul 17, 2016 11:11:53 GMT -5
If I have a 20mm carb I need a 95 to 100 jet correct?
