Post by blenker09 on Apr 11, 2011 18:34:02 GMT -5
Can you find what size wrist pin you have with out taking apart the scooter
its a 2007 TNG LS49
Post by 90GTVert on Apr 11, 2011 19:13:14 GMT -5
I read that the TNG could come with either 10 or 12 depending on year. I would GUESS that being a 2007 it's probably 12mm, but I don't know. The easiest check to make is to pop the CVT cover off and measure or count the splines on your crank where the variator rides. If it has a 10mm pin it should have a 13mm shaft with 17 splines. The 12mm cranks usually have a 16mm shaft with 15 splines.
Post by blenker09 on Apr 11, 2011 19:48:21 GMT -5
Thank you I will look when i have time
