Post by mechanical1990 on Apr 13, 2011 17:29:16 GMT -5
Yesterday I started having a problem when stopped, for some reason the idle just drops, then the engine stalls and it takes a few minutes to restart it. It is running smoothly with no problem, I adjusted the idle up a bit, same problem. The plug looked fine, so I did a pseudo-plug chop (put a new plug in and ran it a half mile, then checked the colour) and that is fine. The spark plug boot isnt loose, battery terminals are tight, and I am confused. Any ideas?
Other info you may need: Kymco ZX 50 2t recently used some oil from walmart, couldn't afford my usual stuff
Post by 90GTVert on Apr 13, 2011 22:11:28 GMT -5
Did you check the plug right after it stalled? That would be the most useful plug check for this scenario.
