Post by speedy1125 on Oct 7, 2011 3:01:05 GMT -5
2.78:1 enviromoto.ecrater.com/p/10358339/stage-6-primary-gear-18-50-gy6-139qmb3:1 enviromoto.ecrater.com/p/10358337/stage-6-primary-gear-17-51-gy6-50-139qmbStock secondary gears are usually 52/15 (3.47:1). With the first set your final drive ratio would be about 9.65:1 and with the second it would be about 10.4:1. I think the stock primary gears are usually 16/52 (3.25:1) to put the stock ratio around 11.3:1. Just for some idea of the effects, I made a little table for ya. Remember, engine RPM doesn't actually work here, because of the CVT. You'd really need to know the RPM of the rear pulley for this to be accurate. Tire size will also affect MPH. This is done just using a 100/90/10 for reference. Again though, this might give some insight into the effects. FD Ratio | 5,000RPM | 7,500RPM | 10,000RPM | 11.3:1 | 22.62MPH | 33.93MPH | 45.24MPH | 10.4:1 | 24.58MPH | 36.87MPH | 49.16MPH | 9.65:1 | 26.49MPH | 39.73MPH | 52.98MPH |
I'm heavy, but I would stay with the lesser upgear (3:1). These engines just don't have tons of power to pull very long gears from my experience, but then again I was 300lbs or slightly over when I was messing with my 80cc GY6. where does a 49/17 fit on the chart?
Post by 90GTVert on Oct 7, 2011 8:04:09 GMT -5
49/17 = 2.88:1, so in between the two sets listed. 9.99:1 final drive ratio.
Post by speedy1125 on Oct 29, 2011 9:31:02 GMT -5
I know why this happened now. The head was milled for 47mm not 50mm. Thats why the piston was hitting the head but the valves werent hitting the piston.
noday
Post by noday on Jun 29, 2012 18:54:21 GMT -5
Post by forde on Jul 15, 2012 5:16:02 GMT -5
why did you file the rings, is that necessary or an enhancement you wanted to perform/
