Post by spaz12 on Oct 11, 2016 21:38:20 GMT -5
Its gonna be a glorious day when she fires up!!😉 It's taken forever it seems to get this far, but it's sooooo close that I can almost smell the smoke
Post by drc174 on Oct 11, 2016 22:36:14 GMT -5
Why no electrical pump? You remove friction in the system. Mechanical pumps feed off engine power, LOSS OF POWAH
Post by spaz12 on Oct 11, 2016 22:57:55 GMT -5
Why no electrical pump? You remove friction in the system. Mechanical pumps feed off engine power, LOSS OF POWAH No way to charge the battery now that I went with a different ignition. I realize that it's sucking power from the motor, but it's not like I'm ever going to race it. And with this I'll be able to ride for a much longer time if the need arises. That, and not everyone has this.
Post by birdman on Oct 12, 2016 13:21:49 GMT -5
I agree with drc174 that the electric pump is better for more all out power but the damn the setup looks trick.
Post by spaz12 on Oct 12, 2016 15:20:43 GMT -5
One of these days I'll disconnect it and run an electric pump so that I can see if there's a big difference. I'll do it all official like with numbers and all that. The Piaggio motor runs an internal pump and we don't give it a second thought.
Post by drc174 on Oct 12, 2016 16:42:25 GMT -5
One of these days I'll disconnect it and run an electric pump so that I can see if there's a big difference. I'll do it all official like with numbers and all that. The Piaggio motor runs an internal pump and we don't give it a second thought. not true On the short case Zip engines I was involved in for the Belgian championship we mounted a reinforced Malossi pump, as we couldnt run a battery for a e-pump BUT would have done it in a heartbeat. I mean I am just nitpicking here, the thing looks dope.
Post by ryan_ott on Oct 12, 2016 19:46:11 GMT -5
I have to say I never noticed a difference when running a electric pump and when I switched back to a mechanical pump. Same top speed, same acceleration, same idle. On my Malossi cast. I think it's a fractional difference in HP. Somewhere I read spinning a normal flywheel at 9,000 uses under a 1/10 hp. So it's probably along those lines. You may see a difference on a dyno but not seat of the pants.
Post by oldgeek on Oct 12, 2016 19:59:46 GMT -5
The amount of power either system uses is likely even closer to being the same than we think. With the electric pump if you use a charging coil to recharge the battery that powers the pump, you loose HP. Nothings free.
Moat
Post by Moat on Oct 12, 2016 20:29:02 GMT -5
Yup. Actually, if anything the electric pump would require more power overall due to the additional energy conversion steps involved, over a straight-up mechanical drive (i.e. - mechanical>electrical>chemical>electro-mechanical). Unless you're running a non-charging, "sacrificial" total-loss battery, anyway. Like oldgeek said... nothing's free.
Bob
Post by nelson on Oct 12, 2016 20:32:03 GMT -5
Man that motor is nice looking, cant wait till it all comes together! What plans you have for the jog? Paint etc...
Post by spaz12 on Oct 12, 2016 20:45:31 GMT -5
Man that motor is nice looking, cant wait till it all comes together! What plans you have for the jog? Paint etc... To make it look a lot like this one, but with a different color scheme.
Post by drc174 on Oct 12, 2016 21:47:16 GMT -5
Yup. Actually, if anything the electric pump would require more power overall due to the additional energy conversion steps involved, over a straight-up mechanical drive (i.e. - mechanical>electrical>chemical>electro-mechanical). Unless you're running a non-charging, "sacrificial" total-loss battery, anyway. Like oldgeek said... nothing's free. Bob Oh yeah, of course a now charging system. Inner rotors dont supply that kind of power anyway. Reminds me of my hillbilly brake lights...
Post by Jwhood on Oct 13, 2016 7:59:51 GMT -5
Man that motor is nice looking, cant wait till it all comes together! What plans you have for the jog? Paint etc... To make it look a lot like this one, but with a different color scheme. I love those track tires on scoots
Post by spaz12 on Oct 14, 2016 20:36:58 GMT -5
Random Shh
Post by ryan_ott on Oct 14, 2016 20:45:31 GMT -5
Ummm.. something is missing
