Post by spaz12 on Oct 20, 2016 12:31:38 GMT -5
Clutch/TD spacers that tsimi got for me. Thank you sir!
Post by PIG on Oct 20, 2016 15:24:39 GMT -5
Shhh, those are the top secret speed boosters. Can't have everyone knowing what we're up too....
Post by birdman on Oct 20, 2016 16:51:25 GMT -5
Oh sick!! Those go betwixt the two sheaves??
Post by spaz12 on Oct 20, 2016 17:16:19 GMT -5
Oh sick!! Those go betwixt the two sheaves?? It goes on the TD right before the clutch. The Malossi over range has an issue with not opening all the way because it hits the clutch, but the spacer moves the clutch further away and cures it. PIG figured this out a while ago. I'm sure others have too and that's why these spacers exist.
Post by oldgeek on Oct 20, 2016 17:21:23 GMT -5
81.4 here I come! (then I wake up)
Post by tsimi on Oct 20, 2016 17:25:16 GMT -5
Post by spaz12 on Oct 20, 2016 19:52:15 GMT -5
I did the rear wheel different. I can't stand how the front looks with a tire on it because to me it looks like the tire has a really tall sidewall. Anyway, I'll mount the tire on this one and go with what I hate the least.
Post by 190mech on Oct 20, 2016 20:03:15 GMT -5
Agreed,black band blends into tire!It aint gonna win grand champion at Oshkosh like that..(OH!wait a minute,we are talking scoots,not aircraft...)
Post by spaz12 on Oct 20, 2016 20:14:40 GMT -5
Agreed,black band blends into tire!It aint gonna win grand champion at Oshkosh like that..(OH!wait a minute,we are talking scoots,not aircraft...) I'd love to go to Oshkosh. Helicopters are my favorite, but would sure like to take a ride in an old Beechcraft D17
Post by PIG on Oct 20, 2016 20:47:16 GMT -5
Good call on the wheels
Post by Jwhood on Oct 20, 2016 21:44:08 GMT -5
What sizes wheels are they spaz?
Post by spaz12 on Oct 20, 2016 21:56:57 GMT -5
What sizes wheels are they spaz? 13's
Post by joshua864 on Oct 21, 2016 0:55:14 GMT -5
I did the rear wheel different. I can't stand how the front looks with a tire on it because to me it looks like the tire has a really tall sidewall. Anyway, I'll mount the tire on this one and go with what I hate the least. I'm interested to know what brake set up you're running and what hub to be able to run a 3 bolt rear rim?
Post by spaz12 on Oct 21, 2016 2:08:25 GMT -5
I did the rear wheel different. I can't stand how the front looks with a tire on it because to me it looks like the tire has a really tall sidewall. Anyway, I'll mount the tire on this one and go with what I hate the least. I'm interested to know what brake set up you're running and what hub to be able to run a 3 bolt rear rim? For your Zuma? I have a Yamaha Aerox 50 motor and wheels. The Aerox 100 rear wheel (which looks the same) has a drum brake and fits the Zuma motor. The front wheel of the 50 and 100 are identical so either can be used, but you need Aerox forks, or need to make a custom caliper adapter. turbotype1 did a write-up on how to convert a drum brake Zuma into disk brake as well 49ccscoot.proboards.com/thread/17194/zuma-rear-disc-brake-conversionI THINK that you might also be able to change the rear output shaft from the Zuma to the smaller Aerox shaft and then buy the Aerox hub and the other parts, but I'm not sure about that. If you're seriously considering the swap, then I'll find links to all the parts you need. It's $$$ btw. Oh, the brakes are Frando HF1's. They're not the same as the Stage6 calipers, which is what my caliper adapters were designed for, but they're close enough that with a little bit of machining they fit.
Post by moofus02 on Oct 21, 2016 2:17:06 GMT -5
You can also get a 3 bolt drum hub for the Zuma to mount the 13 inch wheel. I think pig uses one
