Post by PIG on Apr 23, 2017 15:21:54 GMT -5
The thing with a hyper race is, it'll do 50mph at a quarter throttle. So if your riding it on the streets it has to be tuned fat. Cause a quarter throttle is still 10,000+ rpm. They have to be tuned for WOT and anything less is rich or you'll burn it down. I was following some links from 190mech. It was about race bikes and they were dead reliable wfo but because of part throttle revision they would melt down in seconds at part throttle unless pig rich on needle and pilot This is exactly what I found happening with my build. With the pilot and needle set spot on I would get crazy temp swings. I would constantly have to keep my eye on the temp gauges. And the weather where I live is all over the place making it even more of a bitch to keep the motor alive. It was getting stressful just to ride the dam thing lol.
Post by 190mech on Apr 23, 2017 16:33:43 GMT -5
PIG, You still want to buy this pipe? Do ya mind if I carve a hole in it? Band clamp type EGT probes only require an 1/8" hole.. www.aircraftspruce.com/search/search.php?s=egt+probe&x=0&y=0PS,If you read that section in Jennings book,his answer to smooth carb jetting is to install a 'lesser' pipe and bump up the compression...OOOKAAAY....You hyper race guys get a Technigas on order now!!!
Post by moofus02 on Apr 23, 2017 16:37:59 GMT -5
I want to install the egt probe, but I gotsta put a hole in the pipe to do it. I'll have the bung welded on so that it can be plugged later with a screw in plug. Just remember that when the motor starts to detonate the egt actually goes down. Don't remember why exactly. Egt,water temp and head (under plug temp)would make a nice tuning /safety setup
Post by moofus02 on Apr 23, 2017 16:53:42 GMT -5
spaz12 I should know but can't remember, what pipe are you running on that mhr77 kit?
Post by PIG on Apr 23, 2017 16:58:09 GMT -5
I want to install the egt probe, but I gotsta put a hole in the pipe to do it. I'll have the bung welded on so that it can be plugged later with a screw in plug. You really think it's worth it? You've got it running great and staying alive on the streets without it. I personally wouldn't want that probe sticking out of the side of my pipe. If I was racing it and needed every last drop of power sure. But for what we do, nah.
Post by spaz12 on Apr 23, 2017 18:14:32 GMT -5
spaz12 I should know but can't remember, what pipe are you running on that mhr77 kit? Roost R86
Post by tsimi on Apr 23, 2017 18:16:11 GMT -5
I think a CHT and water temps are good to start with and actually a must have, especially in the class you guys are riding. I agree with PIG on the EGT, that thing is gonna look frigging ugly sticking out there.
Post by spaz12 on Apr 23, 2017 18:18:11 GMT -5
I want to install the egt probe, but I gotsta put a hole in the pipe to do it. I'll have the bung welded on so that it can be plugged later with a screw in plug. You really think it's worth it? You've got it running great and staying alive on the streets without it. I personally wouldn't want that probe sticking out of the side of my pipe. If I was racing it and needed every last drop of power sure. But for what we do, nah. I must have something right because the highest I saw for water temps today was 137. It went to 143 for a bit after I shut it down. So, I guess since I won't be keeping this pipe and she seems to be running okay, then I'll wait until I switch to the new pipe to use the EGT.
Post by spaz12 on Apr 23, 2017 18:19:44 GMT -5
I think a CHT and water temps are good to start with and actually a must have, especially in the class you guys are riding. I agree with PIG on the EGT, that thing is gonna look frigging ugly sticking out there. I just ordered a CHT probe last night and will install it soon. The EGT will be put into the pipe in such a way as to (mostly) hide it from view.
Post by tsimi on Apr 23, 2017 18:20:39 GMT -5
Post by spaz12 on Apr 23, 2017 18:21:45 GMT -5
Soooooo, I did my speed run today. Still have to upload an hours worth of video to the computer and then go through it...
I don't know how fast she went, but I think it was pretty damn fast.
Post by spaz12 on Apr 23, 2017 18:57:27 GMT -5
Any guesses?
Post by moofus02 on Apr 23, 2017 18:58:53 GMT -5
spaz12 I should know but can't remember, what pipe are you running on that mhr77 kit? Roost R86 So what's the new pipe and kit? I'm just trying to catch up on all the build threads I've missed
Post by tsimi on Apr 23, 2017 18:59:07 GMT -5
Post by moofus02 on Apr 23, 2017 19:00:12 GMT -5
64 lol. No really I would say mid 70's wfo cruising. Not sure in a tuck
