dr1445
Post by dr1445 on Apr 20, 2011 21:35:33 GMT -5
i finally got my 19mm dellotro clone carb and new throttle cable back from motion pro. i took the slide out and found no gasket between the top and the body.. now i can not recall if there was one there when i received the carb. i can get one from treatland but i plan to set it up in the morning, how would that missing gasket effect the setup other than a slight change in cable tension when i put a new gasket in?
Post by sidthesloth on Apr 21, 2011 7:09:46 GMT -5
Can you cut a gasket to use? Beats waiting.
dr1445
Post by dr1445 on Apr 21, 2011 9:59:39 GMT -5
that is real thin, not even a 1/4" wide gasket with small ears and small holes in the ears. i put it all together with the new sp3 exhaust and ran it..more work to do and the gasket is on order.
