Post by lindhe on Oct 29, 2009 19:10:19 GMT -5
Yup. Even includes one set of 6 gram roller weights. I've dealt with that seller and he's surprisingly quick from Taiwan. I asked the seller about if it would fit my scooter, and he replied: Do you know you F12 is first generation or second generation? this kit only for second generation model. the major different is rear axle and clutch,bel size,the clutch diameter is 103mm bell diameter is 105mm,this kit will fit to your F12 if your rear clutch the same with Yamaha JOG.Any ideas on how I could find this out? (first generation or second generation?)
Post by 90GTVert on Oct 29, 2009 20:03:56 GMT -5
Just need to find out what year range is first and 2nd gen. Easiest way may be just to tell him what year yours is and any other details.
Post by lindhe on Oct 29, 2009 21:39:46 GMT -5
Just need to find out what year range is first and 2nd gen. Easiest way may be just to tell him what year yours is and any other details. Yeah... I did that... I guess he doesn't know, and Googling doesn't seem to help either. Maybe I'll just take a chance and order it and hope for the best
Post by 2strokd on Oct 30, 2009 8:18:43 GMT -5
Are you planning on installing the vari clutch package yourself? If so your going to have to pull the cvt cover anyway, you might as well pull it off now and measure the clutch bell and check the vari shaft diameter that way you know you are getting the right stuff. You can measure in inches if you cant get it in millimeters, we will help walk you through if you need help ;D. I gotta cam and nothing else to do today.
Post by lindhe on Oct 30, 2009 10:17:11 GMT -5
I barely have the skills to fill up gas in the thing :/ and I have no tools of any kind... buy I appreciate the offer!
Post by lindhe on Oct 30, 2009 12:13:48 GMT -5
Bad news - the seller came back with the info that it will NOT fit my scooter. Good news - I guess this whole exercise has lead us to the following conclusions: 1) My variator size is 13mm2) My clutch diameter is not 103mm 3) My bell diameter is not 105mm
