Post by tsimi on Apr 12, 2017 1:18:46 GMT -5
Thanks Lucas
Post by tsimi on Apr 18, 2017 22:42:17 GMT -5
New parts arrived today. Thanks L! STR 8 CVT Cover Stage6 Throttle assembly Stage6 clutch springs (hardest) Rear brake master cylinder and last....complete, rear Brembo caliper! Hi 'O'Verse Crank and Iggy setup tool should arrive in the next 1-2 days.
Post by spaz12 on Apr 18, 2017 22:58:24 GMT -5
Parts
Post by ThaiGyro on Apr 19, 2017 6:51:55 GMT -5
Post by 'O'Verse on Apr 19, 2017 19:25:55 GMT -5
New parts arrived today. Thanks L! STR 8 CVT Cover Stage6 Throttle assembly Stage6 clutch springs (hardest) Rear brake master cylinder and last....complete, rear Brembo caliper! Hi 'O'Verse Crank and Iggy setup tool should arrive in the next 1-2 days. Nice parts Tsimi. Where and how much was the caliper before shipping to Japan.
Post by tsimi on Apr 19, 2017 19:53:01 GMT -5
'O'VerseThe caliper is used (2nd hand) but almost brand new with brake pads and was part of that package deal so there is no exact price for the caliper only. It was a good and very generous deal.
Post by tsimi on Apr 20, 2017 2:03:40 GMT -5
Received the crank today. That's where the good news end. I ordered 3 things and all 3 arrived but the card board condition and the way they packed that stuff is making me very furious. The Buzzetti install tool was freely and apart inside that huge box the pin which goes inside it was luckily still around. I have no idea why their level of packing became that bad but I now fully understand why oldgeek lost half of his order. I just hope that the crank box was strong enough to prevent any damage to the crank. I will post pictures later. I will write them a very spicey e-mail when I get back from work.
Post by tsimi on Apr 20, 2017 6:14:52 GMT -5
Below you can see some pics. The box looks not that damaged on the pictures but most of the corners have holes in it and the cardboard is something I would expect from an order at aliexpress, China industrial area not from Germany. When I got the box into my hands the parts were loose inside so either the chosen box was too big or too few packing material was used. Small items are just thrown inside and not somewhere fixed like Amazon would do it. If I would have had a front light or tail light in there then that would have been broken now with the Buzetti tool flying around in there. I was lucky that the Buzetti pin didn't drop out of any corner that would have rendered the tool useless. The crank is luckily well packed from the factory so no damage of any kind there. And I doubt the throttle cable can take any damage. I was lucky that it didn't end up like oldgeeks case but I will definitely hesitate to order from them again if they don't fix this issue. Box 1 Box 2 Tool out of its packing All products Crank open
Post by spaz12 on Apr 20, 2017 10:56:23 GMT -5
Too bad that when the motor is together you won't see that crank because those R/T's are a thing of beauty.
Post by 'O'Verse on Apr 20, 2017 11:00:57 GMT -5
This thread is really picking up. I like.
Post by tsimi on Apr 20, 2017 18:29:15 GMT -5
Too bad that when the motor is together you won't see that crank because those R/T's are a thing of beauty. Skeleton engine cases?
Post by spaz12 on Apr 20, 2017 20:14:06 GMT -5
Too bad that when the motor is together you won't see that crank because those R/T's are a thing of beauty. Skeleton engine cases? That might be a lil too drafty lol.
Post by tsimi on Apr 21, 2017 3:21:54 GMT -5
Anyone out there having a Stage6 R/T crankshaft laying around? If yes, what's the number printed on the crank?
Post by spaz12 on Apr 21, 2017 14:58:13 GMT -5
Anyone out there having a Stage6 R/T crankshaft laying around? If yes, what's the number printed on the crank? Is there a problem?
Post by tsimi on Apr 21, 2017 15:44:35 GMT -5
Not sure, that is what I try to find out. Usually there should be the same number printed on the crank as on the box.
For example, the number on the box for this R/T crank is S6-7916685/12 On my R/T crank it says S6-7916688/12
When I search for that number I get search results for the R/T replica crank. Though the replica has a different rod color.
I think 2TDave has a R/T crank.
