Post by tsimi on Nov 16, 2017 18:31:18 GMT -5
spaz12You said the Zuma kick start parts fit just in there?
Post by spaz12 on Nov 16, 2017 21:36:03 GMT -5
spaz12 You said the Zuma kick start parts fit just in there? Oui.
Post by tsimi on Nov 16, 2017 21:38:46 GMT -5
spaz12 You said the Zuma kick start parts fit just in there? Oui. Great! I found out yesterday that I can order most of the Zuma parts here at Yamaha directly and they still sell the kick start assembly. It cost an arm and a leg but if that is what it takes to get it done so be it.
Post by spaz12 on Nov 16, 2017 21:42:01 GMT -5
Post by tsimi on Nov 16, 2017 21:44:54 GMT -5
The stator side gasket is also the same and so is the intake gasket right?
Post by spaz12 on Nov 16, 2017 21:56:08 GMT -5
The stator side gasket is also the same and so is the intake gasket right? Stator side gasket? The grease gasket if using the pump? You don't need that
Post by tsimi on Nov 16, 2017 22:02:21 GMT -5
Post by spaz12 on Nov 16, 2017 22:05:14 GMT -5
Yeah, unless you are using the oil pump, you won't need that gasket. Promise
Post by spaz12 on Nov 16, 2017 22:07:02 GMT -5
The stator side gasket is also the same and so is the intake gasket right? The intake gasket is the same, but what manifold are you getting? A lot of the high-end intakes don't require the gasket.
Post by tsimi on Nov 16, 2017 22:10:54 GMT -5
Thanks for the confirmation. So no need for the stator gasket then.
I am gonna use a VL14 reed block with Malossi 5mm spacer for that reed block. And a Malossi 360 intake. I guess I could use Permatex only.
Post by spaz12 on Nov 16, 2017 22:17:42 GMT -5
Thanks for the confirmation. So no need for the stator gasket then. I am gonna use a VL14 reed block with Malossi 5mm spacer for that reed block. And a Malossi 360 intake. I guess I could use Permatex only. That's what I did as well since the Stage6 intake leaked a little bit on the leak down test.
Post by tsimi on Nov 24, 2017 6:27:07 GMT -5
Early Christmas this week. 2 out of 3 deliveries arrived. Most online stores say that Qty. 1 = 1m of hose. So I assumed that ordering a Qty. of 2 would get me 1x 2m but instead I got 2x 1m. Not sure this is common when ordering hoses online. I don't know if 1m hose is long enough to reach the cylinder. If not I'll have to buy connector joints. Anyways, stuff arrived in good condition and that is what counts even though the box from maxiscoot took quite a beating. Racing Planet Germany on the other hand use very thick and sturdy cardboard and the package got barely any damage.
Post by Raizer on Nov 24, 2017 6:37:35 GMT -5
Post by spaz12 on Nov 24, 2017 15:20:20 GMT -5
You are getting sooo close now! Can't hardly contain my excitement to see it all together and running 👣
Post by birdman on Nov 25, 2017 12:33:53 GMT -5
