Post by oldgeek on Sept 27, 2016 5:55:24 GMT -5
This is the coolest thing I have ever seen! **** a light saber, I want one of these! LOL
Post by Cincikid on Sept 28, 2016 12:30:19 GMT -5
Sweet. Wonder if you could take paint off with it.
Post by Deleted on Sept 28, 2016 14:08:40 GMT -5
Gee, I spent an hour getting rust off my exhaust and all I needed was a laser that costs as much as my Jeep ")
Post by oldgeek on Sept 28, 2016 14:35:13 GMT -5
Sweet. Wonder if you could take paint off with it. Paint, no problem. Pencil marks on paper, no problem.
Post by Deleted on Sept 28, 2016 16:22:53 GMT -5
I have a big block of acrylic, Peterbilt gave it to my father in law, it has a 3d laser etched "sculpture" in the center of it, the lasers are so accurate they can literally burn a specific point in 3d space within 100ths of an inch to create the image inside the block.
Post by humanshield on Sept 28, 2016 16:36:32 GMT -5
Sweet. Wonder if you could take paint off with it. Looks powerful! I wonder if you could take off flesh or a finger with it ? But then...so can my saw....I WANT ONE !! Awesome post Oldgeek !
Post by Deleted on Sept 28, 2016 21:56:16 GMT -5
Oddly, it was because of encounter with a radial arm saw that relegated my right hand to a visually correct but non-functional status. A laser would have least cauterized the wound...
Post by FrankenMech on Oct 10, 2016 23:18:03 GMT -5
I think that unit would be something best used by a shop that uses it every day. I notice it uses an infrared beam. I wonder what type of eye protection is needed.
Post by gsx600racer on Oct 10, 2016 23:51:09 GMT -5
Post by tsimi on Oct 11, 2016 3:18:31 GMT -5
The sound of it is awesome! How much does that thing cost?
Post by Deleted on Oct 11, 2016 20:48:35 GMT -5
couple hundred thousand or so
Post by humanshield on Oct 11, 2016 20:56:18 GMT -5
couple hundred thousand or so No worries.....I just need to figure out how many $4.00 laser pointers I will need to get that kind of total output and bundle them. It works for Flo. Even 1000 of them would only be about $4,000.
Post by 2stroked on Oct 12, 2016 14:28:44 GMT -5
Not laser pointer.
You get old DVD BURNERS and use those lasers Get hundred or so, and the apertures required to hold and focus the beams. A single DVD burner laser will start a piece if writing paper on fire if you focus it good enough. Google it.
Post by Deleted on Oct 12, 2016 17:24:17 GMT -5
Blu-ray lasers are even better. I think if you had a few of those and then, hooked up some long wire to a tall tree during a lightning storm and once you hit 88 mph...oh wait...never mind.
My guess is that very expensive laser probably has a short life span. I do not see how they could keep it cool enough in that small of a form factor.
Bill
Post by 2stroked on Oct 15, 2016 9:46:44 GMT -5
It would certainly need some sort of cooling system. Some type if thermal exchange system or something
Like those sealed cooling deals for CPU cooling in high end towers and game compyters. The DVD burner lasers don't draw much power to run at full capacity so maybe they wouldn't get too hot. A DVD burner only has a small small fan, and some don't even have that. But a large group of them would need something for sure
