Post by stancejontland on Nov 6, 2016 20:25:34 GMT -5
Sup guys need some help taking apart my cluster so I can clean the glass and shroud and things like that I don't have any pics right now but it's the bike in my profile picture
Post by 90GTVert on Nov 7, 2016 13:56:41 GMT -5
I haven't taken apart that body style, but usually you'll need to look for screws on the bottom of 2 panels that form the handlebar cover. Check front and back. Once they're out, there are likely some tabs that mesh together that you'll need to be careful with. Instrument cluster will probably be screwed to a panel and need a speedo cable and a couple of electrical connectors unhooked. Here's me removing the bar cover panels on my TaoTao in case it's of any use : youtu.be/-FVDfP4o9m8?t=6m7s
Post by stancejontland on Nov 7, 2016 20:05:39 GMT -5
looks like all the wires would be in the way maybe its not worth it for me
Post by Deleted on Jan 14, 2017 0:22:54 GMT -5
It looks more complicated than it is, on my Kymco it's 4 screws and tabs, the wiring typically has connectors, hardest part I ever found was not breaking the tabs because I got ham handed and impatient.
