Post by eclark5483 on Nov 9, 2016 2:21:23 GMT -5
Post by Cincikid on Dec 15, 2016 17:28:19 GMT -5
Greggkinney, What method did you use? How did it turn out?
Post by greggkinney on Dec 15, 2016 21:15:13 GMT -5
Greggkinney, What method did you use? How did it turn out? I used super glue to sick it together lol. its held up to 300 miles of w.o.t and a couple more tip overs.(and still holding!!) honestly the only reason i half assed it is because my son in law asked to borrow $20 and I told him if he would sand all the paint off I'd give him 20 and he decided to use gel stripper on it . It ATE HOLES in it way down into the white meat, was so soft the preasure washer I used to get it off cut into it. So i just glued it and am ordering a new fairing. But plain ol super glue held. Used plastic weld on the belly pan as was suggested and it worked great. I believe if i was going to fix the front for real id use the weld and be happy with it. Sandable and nice and hard
Post by greggkinney on Dec 15, 2016 21:25:26 GMT -5
As a matter of fact tomarrow I be live I should post pics of the stripper and its results or devastation I should say before someone else falls victim. Oh along with a review in the body work forums . Son in law might get a lump of coal for Xmas
Post by 180°off on Mar 14, 2017 0:22:12 GMT -5
I have just found that hot glue works very well!
Post by gsx600racer on Mar 15, 2017 3:21:45 GMT -5
I wouldn't hold my breath with hot glue, a few heat cycles and vibrations & road bumps, I'm sure you will be re-gluing again.
Post by greggkinney on Mar 15, 2017 19:39:33 GMT -5
beleive it or not the super glue on the front of mine has held up so far. the plastic weld is great too, ive removed the belly pan and put it back on twice. i figured it would break when i retorqued the screws, but nope its good stuff. thanks for the advice guys.
Post by Cincikid on Mar 15, 2017 20:17:06 GMT -5
What brand of supper glue?
Post by greggkinney on Mar 23, 2017 11:47:37 GMT -5
What brand of supper glue? crazy glue brand from the dollar tree. noticed they had gel or regular and it said gel was less mess and the reg was stronger. i got the regular/original in the dripless bottle. dollar tree everythings a dollar! lmao sometimes you can find good stuff there
Post by ewasleske on Mar 23, 2017 19:18:42 GMT -5
"Amazing Goop" for automotive works well. I glued up my Daughter's rear view mirror and it has held up well. I think it would be a good choice because it remains flexible..good for vibration resistance.
Post by jackrides on Mar 24, 2017 17:26:40 GMT -5
Stick on Velcro strap comes in colors. Cover the exposed sticky side with color tape. As with other adhesives, a Clean and roughed (220 grit sandpaper) is necessary.
Post by greggkinney on Mar 25, 2017 2:47:44 GMT -5
"Amazing Goop" for automotive works well. I glued up my Daughter's rear view mirror and it has held up well. I think it would be a good choice because it remains flexible..good for vibration resistance. ive fixed holes in an old fiberglass jon boat with goop before. duct tape and a spoon work well in an emergency kit for canoes too lol
