Post by wolfvalentine on Nov 19, 2016 16:29:26 GMT -5
FIXED MY BIKE NOW CRUSIN AT 45+ NOW I FOUND A KIT for 100cc is that too much? OH AND YA THINK A CDI CHIP IS A GOOD IDEA FOR NOW? I ALSO NEED A BETTER HEAD LIGHT BULB WHAT MIGHT BE GOOD?
Post by Deleted on Nov 19, 2016 20:27:28 GMT -5
Might try a breaker bar and a spanner wrench before you resort to an impact wrench, cheaper option and you can carry it on your scooter with a spare belt in case you need to change it.
Post by gsx600racer on Nov 20, 2016 1:40:25 GMT -5
If you are cruising at 45+ with 50cc's, why bother putting in the 100cc kit. If......
Post by 90GTVert on Nov 20, 2016 11:43:47 GMT -5
I'm not sure what headlight bulb your scoot uses. If you can figure out the style, or post a pic of the bulb for someone to ID, we may be of more help. There are higher watt or better designed bulbs in most styles though. Lots of them on eBay. You just have to be careful using much higher watt bulbs as they may start to melt the headlight housing. Regarding CDIs... www.youtube.com/watch?v=p63JXW29tVo
Post by wolfvalentine on Nov 20, 2016 20:27:44 GMT -5
Post by wolfvalentine on Nov 20, 2016 20:34:25 GMT -5
This is my bike she has bin tuned well with cheap parts =^∆^= but I want to be able to keep up with traffic down here
Post by 90GTVert on Nov 21, 2016 12:57:56 GMT -5
Post by wolfvalentine on Nov 21, 2016 19:49:05 GMT -5
THANKS FOR THE HELP 90GTVERT UR A BOSS ILL CHECK AND POST UP GOT SOME HAND TOOLS I JUST DONT HAVE A GARAGE TO TAKE IT APART AT LOL
Post by wolfvalentine on Nov 21, 2016 20:07:38 GMT -5
H4 Halogen Headlight Bulb THIS IS THE REPLACMENT STOCK BULB FER SURE 12 Volt 35/35 Watt P43T Base Style Base Diameter: 43mm High/Low Beam 3 Prong
Post by wolfvalentine on Nov 21, 2016 20:44:22 GMT -5
SO MY NEW THING IS MY BIKES BACK TIRE KEEPS SPINNING IS IT CUZ ITS TUNED IN SUCH A WAY OR SHOULD I BUY A CDI FOR THE BIGGER BETTER PARTS I GOT DO YOU THINK THAT MIGHT HELP?
Post by Deleted on Nov 21, 2016 21:02:46 GMT -5
Your back tire is spinning because your idle is set too high and the clutch is engaging. Idle should be around the 1500RPM range, I have mine set at 1600. Leave your CDI alone, it's fine.
Post by 90GTVert on Nov 22, 2016 8:27:00 GMT -5
I agree to try setting the idle speed first. The tire moving a bit is normal, but you don't want the engine revs getting higher and higher as the wheel accelerates at an idle setting.
Good news on the bulb. TONS of choices for H4 bulbs. Even moving to a 45W version may make a big difference. Gotta be careful upping the wattage too much though, as the higher powered stuff runs hotter. I have a 60/65W Silverstar H4 in my TaoTao and it's really bright... but it's also melting my headlight housing. Another option would be keeping 35W, but doing some rewiring so both illuminate with hi and lo beams. I did that to my Roketa and was quite pleased with the result.
Post by wolfvalentine on Nov 23, 2016 18:10:40 GMT -5
WELL IM THINKING ABOUT GETTING LED HEADLIGHTS I HEARD THIER LESS HOT AND SAVE POWER... are you sure I cant upgrade the cdi it still a bit slow idk if its becoming less in tune or its the cold weather but shes topping at 45
Post by 90GTVert on Nov 24, 2016 12:44:44 GMT -5
Upgrade away if you'd like. You can swap it back out easily enough if it doesn't work well. Some report great results, some mediocre.
Post by Deleted on Nov 24, 2016 13:03:52 GMT -5
I'd be willing to bet the only difference between a lot of those orange boxes and a stock CDI is the color ")
