Post by cableguyken on May 10, 2011 7:17:23 GMT -5
I am VERY new to the scoot world...I have a 50cc 2 stroker that is running great...I am getting 55mph with it, and I am almost 300 pounds...I ahve no idea what make it is....or even the year model yet...where can I find the numbers to tell me what kind of motor I have? I found the vin behind a plate under the ''glovebox'' under the handlebars...but have no Idea where the other numbers are....can someone help me out....Ill post pics of the motor if that helps ID it.
Post by 90GTVert on May 10, 2011 7:34:00 GMT -5
If it's a 50cc and you're doing 55MPH at your weight I would guess the speedo is wrong (very common) or it's not a 50cc. Posting pics of the engine and scoot would be helpful. Different engines have the engine numbers in different spots so basically just look the engine cases over well for a series of letters and numbers. Check by the rear of the engine/cvt case up top, near the shock. That's a common spot.
Post by cableguyken on May 10, 2011 10:31:12 GMT -5
speedo isnt off much...the wife was beside me doing 45 and I was reading just over 50...read it wrong yesterday...will upload pics when I get them on photobucket tonight. the guy who owned it was a scooter mechanic...so he may have done some things to it already...but I cant say for sure..because he doesnt know I am the one who has it...long story, but I got it legal...it jumps up to speed real fast....not picking the tire off the ground, but after 10mph...it really takes off...you can feel it toss you back a little. thanks for thehelp....I found a number on the back..Ill get it cleaned up and take a pic of it also.
Post by 90GTVert on May 10, 2011 13:04:32 GMT -5
Well, 45 and 55 are a world apart for a 50cc. That 10MPH up top can be hard to come by. 45 isn't all that uncommon for a 2T unrestricted in good working order. What's the number?
1E40QMB or something really close to that is one of the most common, good running, 2T scoot engines.
Post by cableguyken on May 10, 2011 15:33:07 GMT -5
Still cant quite read the number, but here is a shot of the case on the drive side. and here is the wheel side.
Post by 90GTVert on May 11, 2011 9:20:45 GMT -5
That's a 1E40QMB / Minarelli / Jog motor. The number will be right near where the rear shock mounts to the engine/cvt case. It could possibly be some other variation of that motor, but it's definitely the minarelli/jog style of engine. Lots of performance parts available and lots of info on them in our Tech Library. ;D
