Post by 190mech on Apr 7, 2018 3:54:26 GMT -5
That case will fit either Aldys as both are the same length..
Post by Jwhood on Apr 8, 2018 19:23:01 GMT -5
Any one know the size of the rear axle nut for the wheel axle I bought didn't come with one
Post by 90GTVert on Apr 9, 2018 10:06:43 GMT -5
The axle on the Adly engine that I have matches up to a 1.5mm thread pitch and measures 13.8mm diameter, so it should be M14x1.50.
Post by Jwhood on Apr 10, 2018 21:12:13 GMT -5
The axle on the Adly engine that I have matches up to a 1.5mm thread pitch and measures 13.8mm diameter, so it should be M14x1.50. The axle I have is from a stock 1e40qmb setup it's not an adly axle brent
Post by 90GTVert on Apr 10, 2018 22:02:19 GMT -5
You can measure the OD and measure the distance from peak to peak of the threads as accurately as you can (or use a thread pitch gauge). I'm too tired and lazy to go out ATM and attempt to check.
Post by 90GTVert on Apr 12, 2018 19:58:33 GMT -5
Forgot about it when I was in the garage yesterday, but not today. The long case 1E40QMB has M16x1.50 on the axle. I didn't want to drag it out and disassemble the Venus just to measure, so I measured the best I could in the corner with the nut on. Looks like M14x1.50 on that. So the short case and the Adly both appear to be M14x1.50. That would be my guess, but I still say it doesn't hurt to measure to be certain if you haven't already got it figured out.
Post by Jwhood on Apr 13, 2018 4:09:34 GMT -5
Forgot about it when I was in the garage yesterday, but not today. The long case 1E40QMB has M16x1.50 on the axle. I didn't want to drag it out and disassemble the Venus just to measure, so I measured the best I could in the corner with the nut on. Looks like M14x1.50 on that. So the short case and the Adly both appear to be M14x1.50. That would be my guess, but I still say it doesn't hurt to measure to be certain if you haven't already got it figured out. Thanks again as always brent I'll be hitting Ace hardware this morning and grabbing some more Allen head cvt cover bolts,also ordering the cvt cover and 2 tires so I can swap these nice 5 spoke Triton wheels I've had in the stash,I'll post up pics later of the zx 100 exhaust that I have to change head angle,the guy I know that does welding moved so now I gotta find someone to cut and re angle the header on the pipe,been looking on c.l for a mobile welder in my area but not finding too much or there prices are too high and I'd like it to look 1/2 decent once it's finished,I'm torn between the 100 60 12 tires f and r or the 120 70 12 f and 130 70 12 r the lower cost tires are only 4 ply while the more $$ ones are 6 ply+ leaning towards the second option?
Post by Jwhood on Apr 21, 2018 21:14:07 GMT -5
Sent engine out with leo pipe to be perfectly welded just waiting on tire for the wheel so engine is completely mocked up so he can see clearance on the rear tire hopefully in the next 2 weeks I'll be rolling again
Post by Jwhood on Apr 22, 2018 14:16:39 GMT -5
Post by Jwhood on Apr 22, 2018 14:37:46 GMT -5
Can any one give me the measurement on an adly long case from the center mount tube to the center rear shock mount I don't have my engine now and need to figure how much longer of a shock I need the Tgb morini engine is 11 3/8 from center to center I wanna see how far back the adly shock mount is,my Tgb shock is 10 5/8 long
Post by moofus02 on Apr 22, 2018 15:57:35 GMT -5
This is a adly style motor or a true short case? I can go out and measure one in a few minutes
Post by moofus02 on Apr 22, 2018 16:02:10 GMT -5
14 13/16 is what i measure on my adly
Post by benji on Apr 22, 2018 16:07:39 GMT -5
I like the rims! 18 spline 110mm drum, right? I'm gonna use those w my race motor I think (when I actually build it)
Post by moofus02 on Apr 22, 2018 17:36:52 GMT -5
I like the rims! 18 spline 110mm drum, right? I'm gonna use those w my race motor I think (when I actually build it) Look like triton gt5 wheels. Are you using the adly axle or clone short case axle?
Post by Jwhood on Apr 22, 2018 23:38:18 GMT -5
This is a adly style motor or a true short case? I can go out and measure one in a few minutes True adly it's a canam Ds 90 engine has adly stamped all over it,it's got clone axle and a m14 nut moof
