An update, planning for next steps
as you saw in my post ive cut and flipped the header section of the exhaust. I added 0.8 mm to each side so i would have the outer diameter of the pipe to fit. glued it on cardboard, and its clearing the stand and engine case now.
I then printed out the cone to the inner diameter nr from fospipe, drew al the lines at same angles and distances again, and measured all the dimensions. Ive downloaded the cone program and thanks to 190mechs posts I know now how to work with the cone program.
Tomorrow ill input al the numbers for the header, and ill try to do the next piece aswel.
What im not certain about
, about the flange, I desinged my flange to be the outer tube, and my exhaust will then fit into that 20 mm of flange pipe of the flange, I was thinking viton rubber and liquid gasket sealant to make sure it doest leak, and using 2 strong springs to hold/push the pipe into the flange.
Now, the header is at an angle, so I dont know for sure how far it wil go into the flange, you kinda feel where im going here, I could use some tips and tricks concerning the connection between flange and exhaust.
Ive seen many exhaust doing the opposite, ea the pipe fits over the flange, with a rubber in between.
Do you think my way will work out fine or should I redesing a straight section on the header, and make that fit over the flange?
Also my flange is 5 mm thick, should I cut 5 mm of the header? Im getting really close now to ordering the lazerd parts, but I'm a bit wary and a perfectionist... also, dont want to end up with a bunch of parts that wont be good.
so, my plan atm, more or less -->
The start of the header is 30.6mm, the hole in the flange will be 32mm or a bit more, the 20mm length tube that fits and gets welded into the flange hole should be 31mm inner diameter +- depends on what I can get... (I can hammer it into shape a bit if needed)
So of the 20mm length 32 outer diameter and 31 inner diameter pipe, 5mm slides into the flange plate, and 15mm is sticking out.
Then the header will fit snugly into the flange tube since its taperd, ill ad a rubber viton seal 30mmx1mm in between both and smear liquid gastet on the header, like toothpaste, attach the springs to hold/puch the header into the flange, ill make those pull real hard.
This way I can twist the header into the right direction, to the side.
The header ends with a straight edge.
The first stage diffuser starts with same diameter straight edge, ill make that one out of 3 sections again with 2x 5° cuts in the middlde and straigt at start and end,
and that i hope), should be enough play to flip and turn the rest of the exhaust into a position where I can desing the suspension points.
The2nd stage diffusor can then be made in just one piece.
Next the belly wil be straight at start and end, but ill do one cut 5° or 7.5° in the middle of the belly so I can flip that and have that cool look the roost exhausts have).
Then the end cone wil be straight, but cut in 2 sections, from 102mm to 28mm so I can use my rolling machine,
and the second end part of the end cone from 28mm to 11mm can be hand/hammer bent on a 11mm solid rod (11 mm is too smal for the slip rol).
Finally, ill have to order a slip-on or clamp-on Roost (70€) or Stage 6 (100€) or yasuni silencer (100€), and I'll have to order/fabricate the stinger somewhere/somehow.
For the stinger, best idea I have now is to order 2 mandrel 90° bends, and a tube of same diameter/thickness as the 90° bends, so I can customize the stinger to position the silencer, so that the silencer can be clamped on to a nut , welded to the exhaust.
Ill weld a M10 nut onto the exhaust for the bolt of the silencer clamp.
Final step, ill take a piece of 1mmm plate, grind and bend and drill it to make the suspension bracket between the exhaust and the engine case, this shoudnt be to hard.
Think I got it pretty well figured out now, but I'd love your input on all this. Its become quite the project I must say and much respect to you for doing what you do 190mech.
And now time for some shut eye
PS the exhaust is pretty much the same as a Yasuni C16, only I worked out the numbers better according to physicsthis formulas i got from some 2stroke tuners book. It should perform a tad better. Id liketo build the exausts under the name
Son Of Michael" and I'll name this type "SOM
R16", good name or find something better?
N8N8 all
